Engine swap no start no injector pulse - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 12-30-2018, 07:56 PM Thread Starter
Has anyone done an engine swap successfully? I have swapped an Australian spec 2004 2.3L engine and 4 speed auto from a GG Mazda 6 (my old car) into a 11/2003 GG Mazda 6 shell (my new car). I cannot start the mutha. The starter motor turns but the engine doesn’t fire up. (Strangely, when I change to my old ecu, the starter motor doesn’t turn and I see the immobiliser check light flashing rapidly).
When spraying hydrocarbons into the throttle body the engine seems to want to fire up suggesting I’m getting spark. The spark plugs and cylinder bore is totally dry suggesting injectors aren’t firing. There’s plenty of fuel as tested by removing the fuel line and draining into a bucket while engine is cranked. All electrical connections have been checked countless times.
Is there a BCM or immobiliser module I need to swap over from my old car? I cannot find any modules except for the ecu at the footwell and Visteon remote box under the drivers dash. There appears to be no BCM in my car (ie. grey box with multiple plugs). I have looked in the engine bay near the battery/fuse box/engine bay as well under dash/glove box, under seats and found nothing. There’s only a fuse junction box with fuses (as pictured under glove box) but I have swapped this from my old car too without success.
Help is much appreciated.
mazda6thsense is offline
post #2 of 6 (permalink) Old 12-31-2018, 10:03 AM
b1lk1's Avatar
Quoted: 282 Post(s)
Groans: 19
The keys, steering column, instrument cluster and PCM/ECU all must match for the car to run properly. Someone with a dealer level scan tool can also do the flashing. Be careful not to put it into theft mode as that requires a dealer level scan tool to flash it to run.
b1lk1 is online now
The Following User Says Thank You to b1lk1 For This Useful Post:
striver (12-31-2018)
post #3 of 6 (permalink) Old 12-31-2018, 12:37 PM
Quoted: 390 Post(s)
I recently changed my standard instrument cluster for an electroluminescent specimen and had no issues. 06/2004 GY into 05/2004 GY. It would seem the US instrumentation is exempt from this security issue.
Sorry I have nothing more.
Modifications:
.MSP brakes &
slotted rotors (320mm)
DrFeelGood is offline
post #4 of 6 (permalink) Old 12-31-2018, 07:01 PM Thread Starter
Interesting. I was able to run my old car with a generic blank key so how does the steering column and cluster sense things don't match up? Also if the ecu is in theft mode will it stay in that state forever and useless unless dealer reset?
post #5 of 6 (permalink) Old 01-01-2019, 08:59 AM
bluedevil6's Avatar
Quoted: 191 Post(s)
@mazda6thsense Is it possible that an immobilizer was optional on the Australian spec models? In that theory if the donor car did not have one and the new one does it could be possible thatís your problem you could try swapping the computers and ignition from the old car and see if that makes a difference. I donít think it has anything to do with the instrument cluster because as DrFeelGood I too have swapped mine for the electroluminescent ones with no issues.
2007 6 Hatch 3.0 V6 ATX
Places to find me-
bluedevil6 is online now
post #6 of 6 (permalink) Old 01-01-2019, 08:53 PM Thread Starter
There seems to be an active immobiliser on these models evidenced by lack of cranking with old ecu and security light flashing but it's a question of how to overcome it. I'll check other things with new ecu since i at least get cranking before resorting to changing ignition barrel.
