Won't start! Pls help! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 07-16-2019, 04:38 PM Thread Starter
Hi everybody, i'm from Hungary so sorry for my bad English! I have a 2005 Mazda 6 with a 2.0 diesel engine. I stopped the car at night (with no symptom) and it didn't start in the morning. It cranked but it won't start... I checked the timing, it is good. Somebody could help me?
Dew971011 is offline
post #2 of 9 (permalink) Old 07-16-2019, 06:05 PM
Quoted: 174 Post(s)
Groans: 10
Is it cranking as usual ? A dying battery can try to crank but may not have enough juice to get the motor running, so that's the first thing i would check. May sound obvious but check if you have enough fuel. I'd then go on to the fuses for the injectors. Eliminate the simpler things first before moving on to the fuel and air delivery systems.
MilR is online now
post #3 of 9 (permalink) Old 07-16-2019, 07:45 PM
Quoted: 466 Post(s)
Did someone steal your fuel?
Mozz-D
DrFeelGood is offline
post #4 of 9 (permalink) Old 07-16-2019, 11:48 PM Thread Starter
I think no. It turning the engine but no "explosion" only sometimes.I tried 3 different battery and nothing. The tank is almost halfway, so i think it is okay.
post #5 of 9 (permalink) Old 07-18-2019, 01:47 PM Thread Starter
So anybody could help me?
post #6 of 9 (permalink) Old 07-18-2019, 03:08 PM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2907 Post(s)
Is the engine flooded?
I don't know if this work on diesel engines but if you attempt to start the car with your foot on the gass 100% and hold it there for a few seconds, it puts the car into 'flood mode' and (hopefully) get it started again. I had to do this to my wife's Mazda 3 a few months ago because she got some bad gas and the car's O2 sensor was going.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #7 of 9 (permalink) Old 07-21-2019, 10:56 AM Thread Starter
Still nothing.
post #8 of 9 (permalink) Old 07-21-2019, 02:26 PM
MazdaMetalhead's Avatar
Quoted: 161 Post(s)
You may want to research this further, but I've read before that a spritz of WD40 into the air intake can help with a hard-starting diesel engine. I believe regular starting fluid is bad for a diesel. Sounds like a fuel delivery issue, but I don't know much about diesels.
Manual transmissions, wagons, and heavy metal are awesome. Zoom-Zoom \m/
2004 Mazda 6s Wagon - 3.0L V6 | 5MT | Steel Gray Metallic |
Mods: 2015 OEM 17" 6 rims | NGK Iridium IX plugs | Matte black painted OEM wheels (winters) | Red painted calipers | Light black "smoked" headlights | R1 Concepts eLine rear rotors and pads | Rear V6 emblem added
Other Mazdas owned: 2015 Mazda 5 Sport ATX (current), 2010 Mazda 6 ATX (traded), 1997 Protege MTX (sold)
MazdaMetalhead is offline
post #9 of 9 (permalink) Old 07-21-2019, 03:51 PM Thread Starter
I did this with brake disc cleaner and still nothing... Just sometimes one "bang" and turning.
