Car won't start please help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 40 (permalink) Old 06-01-2019, 07:56 PM Thread Starter
Thomas Ayala's Avatar
Quoted: 20 Post(s)
SOOOOOO my 2005 Mazda 6 wagon won't start. I turn the key and it won't turn over. I have currently disconnected the battery and I'm leaving until I find a solution. Please help.....
Sent from my Pixel 2 XL using Tapatalk
Thomas Ayala is offline
post #2 of 40 (permalink) Old 06-01-2019, 08:06 PM
idrive's Avatar
Quoted: 299 Post(s)
Groans: 6
Does it make any sound(s)? Tick tick tick maybe? = Battery
Super sluggish, barely turns over and then stops? = Battery
Being you already have the battery disconnected take it to a parts store and have it tested or if you have a battery charger, charge it.
Will need a lot more information if the battery is ruled good.
Depending on the answers to my question you may have a bad ignition switch. It's a start (no pun intended)
Build Thread:
idrive is offline
post #3 of 40 (permalink) Old 06-01-2019, 08:09 PM Thread Starter
Quoted: 20 Post(s)
When I turn the key the radio and cluster turn on . Nothing else . Thank you for your response
post #4 of 40 (permalink) Old 06-01-2019, 08:24 PM
idrive's Avatar
Quoted: 299 Post(s)
Groans: 6
A bad or dying battery that won't turn the engine over can still light up your dash, run the radio.
DrFeelGood likes this.
Build Thread:
idrive is offline
post #5 of 40 (permalink) Old 06-01-2019, 08:25 PM Thread Starter
Quoted: 20 Post(s)
But I also tried jumping it and it didn't work. I'll probably still take it to AutoZone for a charge
post #6 of 40 (permalink) Old 06-01-2019, 08:30 PM Thread Starter
Quoted: 20 Post(s)
My multi meter says 12.64 on the battery
post #7 of 40 (permalink) Old 06-01-2019, 08:39 PM Thread Starter
Quoted: 20 Post(s)
Ok so the car is not making any ticks or clicks so does the mean ingnotion switch is bad
post #8 of 40 (permalink) Old 06-01-2019, 09:22 PM Thread Starter
Quoted: 20 Post(s)
Ok I got the ing. Switch off
post #9 of 40 (permalink) Old 06-01-2019, 10:57 PM
idrive's Avatar
Quoted: 299 Post(s)
Groans: 6
Was kind of hoping we'd have some other folks jump in...
I don't know that car well so it's very possible there is something simple that can be checked or there is a known problem other might know about.
Are you able to take the ignition switch out and jump it? See if that turns it over? If the battery is good then it could possibly be the Start solenoid is bad or the starter itself.
Build Thread:
idrive is offline
post #10 of 40 (permalink) Old 06-01-2019, 10:59 PM
idrive's Avatar
Quoted: 299 Post(s)
Groans: 6
When you turn the key on and you hear the ticks that's a battery that doesn't have enough juice to crank the engine.
Build Thread:
idrive is offline
