Preventative Maintenance for Spark Plug Change - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
  • 1 Post By waughoo
  • 1 Post By hurddawg
post #1 of 10 (permalink) Old 04-01-2019, 01:39 PM Thread Starter
Quoted: 21 Post(s)
Hello everyone
I am currently in the middle of replacing my spark plugs on my 07 3.0 V6. I'm replacing all 6 coils and plugs, but is there anything else I should consider replacing while I have the upper intake manifold/tb/egr exposed? vehicle has 145k on it.
thanks!
post #2 of 10 (permalink) Old 04-01-2019, 03:53 PM
waughoo's Avatar
Quoted: 422 Post(s)
I also did my valve cover gaskets and intake plenum gaskets while I had my intake off. This allows you to take care of the plug well gaskets that can leak and cause issues with your new plugs.
[email protected] likes this.
Alex
, and
waughoo is offline
post #3 of 10 (permalink) Old 04-18-2019, 11:38 AM Thread Starter
Quoted: 21 Post(s)
Good call. plug well gaskets were shot.
Anything else? Maybe a catch can?
post #4 of 10 (permalink) Old 04-20-2019, 01:41 AM
PeteGT6's Avatar
Quoted: 7 Post(s)
I recommend a catch can. I installed one a few weeks ago and within one week it already had an ounce or two of a water/oil mix. I’ll be checking it again next week.
PeteGT6 is offline
post #5 of 10 (permalink) Old 04-21-2019, 10:45 AM Thread Starter
Quoted: 21 Post(s)
Originally Posted by PeteGT6 View Post
I recommend a catch can. I installed one a few weeks ago and within one week it already had an ounce or two of a water/oil mix. Iíll be checking it again next week.
Link to the catch can used/ setup? concerned with location & bay space.
post #6 of 10 (permalink) Old 04-21-2019, 11:14 AM
hurddawg's Avatar
Quoted: 59 Post(s)
The PCV valve if you haven't changed it yet already.
- 1957 Chevrolet Sports Sedan
hurddawg is offline
post #7 of 10 (permalink) Old 04-21-2019, 12:18 PM Thread Starter
Quoted: 21 Post(s)
Thanks! yep, took some time to find the right size, but Its shipping now. Just wondering if i can clean / inspect anything that can preserve my life
post #8 of 10 (permalink) Old 04-21-2019, 04:20 PM
PeteGT6's Avatar
Quoted: 7 Post(s)
I ordered a universal catch can from UPR products with the L shaped bracket and diffuser also. eBay had the best price. I really like their design. If you research you will find cheaper solutions where some people will add a stainless steel pan scrubber for media which likely will do just as well. I did this on a 2015 6 so i’m not sure where the best mounting position would be on yours. For me the only logical option was to mount just behind the drivers side fog light to where I have to pop open a plastic cover underneath the vehicle to access it. My alternative was up near the passenger side firewall but I was looking at about 12ft of hose to do all this. I plan to add a drain which is easy with the upr catch can but you can also order a drain from them.
PeteGT6 is offline
post #9 of 10 (permalink) Old 04-21-2019, 04:27 PM
PeteGT6's Avatar
Quoted: 7 Post(s)
You may check out your intake valves and try to clean them up if they are caked with deposits. I scrubbed them with acetone but did not get as much off as I would like. A walnut media blaster is likely the way to go and I will probably do this when I try and do it again. CorkSport sells one for a decent price but some people make their own. If your generation Mazda is port injected then this is probably a waste but I would still inspect them.
PeteGT6 is offline
post #10 of 10 (permalink) Old 04-21-2019, 05:52 PM Thread Starter
Quoted: 21 Post(s)
Thanks! Ill look into it. valve deposits are an concern, hence the catch can. Yeah mine is DI so I will see if I can clean them up a bit.
Similar Threads
Attempting spark plug change htappy Newbie Section 4 08-25-2018 12:58 PM
How to Change Your Dash Colors HyTeK Interior Modifications 197 04-25-2017 02:12 AM
Preventative maintenance too2buff Newbie Section 4 01-28-2005 07:01 AM
DIY Oil Change Instructions LBJay Engine / Drivetrain 77 06-14-2004 02:10 PM
My oil drain plug is jammed! bkrodgers Engine / Drivetrain 10 06-05-2004 02:10 AM
