Cel codes 04 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
  • 1 Post By milemarker15
post #1 of 9 (permalink) Old 05-09-2018, 06:17 PM Thread Starter
Cel codes 04
Any input on fixing codes p0132, p0138, p0442 and p0455 ?
Jef5772 is offline
post #2 of 9 (permalink) Old 05-09-2018, 07:56 PM
Quoted: 417 Post(s)
The P0132 and P0138 are both oxygen sensor codes (circuit high). solution --> replace all O2 sensors with NTK (OEM)
The P0442 is a small evap leak. Solution --> tighten your fuel filler cap (or likely replace with Mazda only. Aftermarket rarely work here) could be purge valve.
The P0455 is a large evap leak. Solution --> tighten your fuel filler cap (or likely replace with Mazda only. Aftermarket rarely work here) could be purge valve.
Without knowing your engine I cannot give you more specific information but ordering all new O2 sensors and a fuel cap should fix the codes.
Happy motoring.
DrFeelGood is online now
post #3 of 9 (permalink) Old 05-12-2018, 03:27 PM
Quoted: 4 Post(s)
Happy motoring.
I agree with DrFeelGood regarding P0442.
After Mazda original fuel cap failed I replaced with aftermarket, each lasted only 1 year.
Once the second aftermarket failed after 1 year I picked one up from the dealer (5 years ago).
milemarker15 is offline
post #4 of 9 (permalink) Old 05-15-2018, 04:27 PM Thread Starter
04 mazda 6 3.0...looking for ntk part number for bank 1 o2 sensors 1and2
Jef5772 is offline
post #5 of 9 (permalink) Old 05-19-2018, 10:26 PM
Quoted: 4 Post(s)
Direct Fit Oxygen Sensor 22118 Upstream Rear (B1S1) OE MFR: NTK
Direct Fit Oxygen Sensor 22097 Downstream Rear (B1S2) OE MFR: NTK
You didn't ask for bank 2 but figured I would include it anyway.
Direct Fit Oxygen Sensor 22115 Upstream Front (B2S1) OE MFR: NTK
Direct Fit Oxygen Sensor 22100 Downstream Front(B2S2) OE MFR: NTK
DrFeelGood likes this.
post #6 of 9 (permalink) Old 05-20-2018, 10:56 AM
Quoted: 417 Post(s)
The lifetime of these 4-wire sensors is 100,000mi. After time they slow in response and can lead to fueling error and catalyst failure. I would replace all 4 if 2 are presenting codes. well done @milemarker15
Full Catalyst Replacement parts list
post #7 of 9 (permalink) Old 11-04-2018, 02:51 PM
MazdaMetalhead's Avatar
Quoted: 153 Post(s)
Is there a diagram of the locations? Specifically rear upstream. I just got a P0132 and I'll be doing the coils and plugs anyway. I just don't know where it is.
Manual transmissions, wagons, and heavy metal are awesome. Zoom-Zoom \m/
2004 Mazda 6s Wagon - 3.0L V6 | 5MT | Steel Gray Metallic |
Mods: 2015 OEM 17" 6 rims | NGK Iridium IX plugs | Matte black painted OEM wheels (winters) | Red painted calipers | Light black "smoked" headlights | R1 Concepts eLine rear rotors and pads | Rear V6 emblem added
Other Mazdas owned: 2015 Mazda 5 Sport ATX (current), 2010 Mazda 6 ATX (traded), 1997 Protege MTX (sold)
MazdaMetalhead is online now
post #8 of 9 (permalink) Old 11-04-2018, 06:53 PM
Quoted: 417 Post(s)
Name:	2004 Mazda 6 AJ Exhaust Diagram.jpg
ID:	224950   Click image for larger version
Name:	2004 Mazda 6 AJ Exhaust Tightening Diagram.jpg
post #9 of 9 (permalink) Old 11-04-2018, 07:08 PM
Quoted: 153 Post(s)
Thanks, you da man!
