Hello,
We are pleased to announce our Xtreme line up, it is currently on special for members priced at $225! http://www.xenonexpert.com/xtreme_hid_sale.html The Xtreme line up is available in the following colour temperatures: 3000k - Intense Yellow 4300k - Bright White 5000k - Crisp White 6500k - White with a purplish hue 8000k - Blue output ![]() The Xtreme HID Conversion kits utilize cutting edge HID components made with superior Japanese craftsmanship and quality. Laser calibrated bulbs are used to ensure proper fitment and optically correct beam patterns. The ballasts used in this product are uniquely designed for aftermarket applications as they are completely epoxy sealed to protect against harsh weather conditions. In aftermarket applications, ballasts are often mounted outside the headlight leaving them susceptible to water damage. The Xtreme ballasts are specifically designed for these applications making them the superior choice for your aftermarket HID upgrade. BALLAST SPECIFICATIONS: - Xtreme HID ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output. - Xtreme HID ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour. - The Xtreme HID ballasts are designed for both 12V and 24V applications. - Equipped with advanced polarity protection system This product will include a complete wiring harness that will literally plug directly into your OEM headlight harness via proper mating connectors. The harness provided will include upgraded fuses and relays to ensure you do not draw a higher current from your stock wiring harness than it was designed to provide. Furthermore, the harness is set up in a way so that each side has its own harness. Each side will have its own fuse, relay, trigger, etc.. This way, should a relay, fuse ever go out on you one headlight will still function. Technical Data: Nominal Voltage: Dual voltage ballast system for 12V/24V Bulb Voltage: 85 +/- 17 (V) Bulb Electric Power: 35 +/- 3 (W) Operating Temperature Range: -40 ~ +95 Storage Temperature Range -40 ~ +105 Operating Voltage Range: 9 ~ 32 V Inrush current (0-5msec): <45 (A) Reverse Polarity Protection: Yes This product will include: 2 x Laser Calibrated HID/Xenon Bulbs 2 x Xtreme HID Ballasts 2 x Complete Wiring Harnesses – 1 per side Mounting Hardware Complete Instruction Manual GET IT HERE: http://www.xenonexpert.com/xtreme_hid_sale.html Hope This Helps, Oliver ![]()
Xenon Expert</span>[/b][/url] |
