Can't decide - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Go Back   Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Technical / Performance / Model > Mazda 6 1st Generation (2002-2008) > Wheels / Tires
New User? Register
Old 11-15-2012, 07:16 PM   #1 (permalink)
KWhale's Avatar
Default Can't decide
Ok. I need new tires soon. Cannot get the Continental Extremecontact DWS set because they are backordered until next year and i need them sooner than that. Bridgestone Potenzas are out of my price range. I am torn between the Kumho Ecsta 4X and the General G-MAX AS-03. I like them both and they are about the same price. May not make a difference but the size is 225/45R18 on a set of RX-8 wheels and driving in the standard IL weather (ie shit).
Any opinions on them? I just can't figure out which set to get.
2003 Mazda 6i MTX Glacier Silver
KWhale is offline   Reply With Quote
Old 11-15-2012, 07:21 PM   #2 (permalink)
Smoke Screen
Mr.Smoke's Avatar
Groaned at 4 Times in 4 Posts
Quoted: 657 Post(s)
I had a set of Kuhmo tires on a previous car and enjoyed them. Never used either of those exact tires but did have a good experiance with Kuhmo so they get my vote.
CLICK HERE TO CAST YOUR VOTE FOR 6OTM!!
Mr.Smoke is online now   Reply With Quote
Old 11-15-2012, 11:43 PM   #3 (permalink)
MATR6's Avatar
Quoted: 16 Post(s)
235/40s will probably fit the RX8s better & the DWS in that size is in stock at Tirerack.
'07 Speed6 GT LPM #8903
AutoExe Low Down Springs | Billstein HD | CARLED Tailights | Mazdaspeed OC | Redline Goods SB | TWM Stage 1 SS & Bushings | XCarlink | Enkei RS5 18X7 42mm offset | 225/40 Hankook Ventus V12 EVO K110
MATR6 is offline   Reply With Quote
Old 11-16-2012, 12:42 AM   #4 (permalink)
KWhale's Avatar
I saw that on there but I just like the way the 225/45 look. Plus, idk if the 235/40 size will give me rubbing issues. I have already had them with the current 225/45.
Old 11-16-2012, 07:58 AM   #5 (permalink)
corey6's Avatar
i have the gmax as-03's and fuckin love them. had them for about 15k now and there is legit almost no wear.
corey6 is offline   Reply With Quote
Old 11-16-2012, 08:03 AM   #6 (permalink)
MATR6's Avatar
Quoted: 16 Post(s)
http://www.conti-online.com/generato...tasheet_en.pdf
The 225/45 has a diameter of 26in & width of 8.9in while the 235/40 has width of 25.4 & width of 9.5, so it might be wider tire, but will give you 1/2in more fender gap, which may reduce the rubbing.
You should roll your fenders with RX8s anyways.
Old 11-16-2012, 08:51 AM   #7 (permalink)
Mz6GreyGhost's Avatar
Groaned at 23 Times in 19 Posts
Quoted: 124 Post(s)
Between the Kumhos and Generals, I'd get the Generals. I've been hearing nothing but great things about the Generals lately. The Kumhos are also probably a good choice, but they're quite new to the market (a year old IIRC), and the verdict is still out on them in terms of long-term use.
If you're willing to experiment on the size, I'd jump at the DWS.
Injen SP Intake | Tinted Sidemarkers | H9 3000K Fogs | 6000K HighBeams | LED Switchbacks | Full LED Taillamps
Mz6GreyGhost is offline   Reply With Quote
Old 11-16-2012, 09:09 AM   #8 (permalink)
corey6's Avatar
yeah i was stuck between the kumhos and the generals and the wear rate on the kumhos were pretty bad. SO i got the generals. Great grip around corners, quiet, takes bumps a little harder because of the stiffer sidewall but it helps alot with handleing. and they are wearing fantastic.
Old 11-17-2012, 12:58 AM   #9 (permalink)
KWhale's Avatar
MATR6, I do have them rolled. Are there any benefits to a wider and slightly smaller (diameter) tire besides looks? Everyone else, thanks for the input. Currenty have Kumho ASX's on now so i think i might give the generals a try
Old 11-17-2012, 02:28 PM   #10 (permalink)
MATR6's Avatar
Quoted: 16 Post(s)
I had 225/45/18s on my 18X7 with 42mm offset & rear fenders rolled & they rubbed over bumps & RR crossings. Switched to 225/40 & the rubbing went away. 225/45 is higher profile than OEM, so the suspension is not set up for both the aggressive offset of the RX8s & higher profile tire.
Since you can't really change the offset of the wheels w/o getting new ones, changing to a lower/wider tire might reduce the rubbing.
There are wheel/tire calculators online that help with the calculations.
A wider & lower profile tire will help with handling but a loss in little ride quality.
Good luck.
You should come to one of our Midwest meets. A few guys run RX8s & you can see what tires they're running.
