I want to buy these Rota Torque Rims of 18" by 9.5 et35.
They are 5x114.3 so they should fit the six. My question is, seeing as I am new to calculating offset and such, will the wheels touch the caliper at all or will I be okay? Cheers
2002 Mazda 6 Limited series 1 Manual 2.3L I-4 Australian Model (Jap Spec) 10:6 High Compression Current Mods: BC Racing Coilovers | Injen CAI | Advanced Timing | Dark Yellow Smoked Fog Lights | 18" Mazda RX-8 Wheels on Bridgestone GIII 225's | Raybrig 4500K Pure White Parker/licence/door Bulbs imported from Japan | Audiolink ipod Connection | Fluoro Orange Rocker Cover | Custom Grounding Kit | Breather Air Filter | Apexi Turbo Timer | PCV Oil Catch Can (Still need to install) | RDA Front Slotted Rotors | ACRE Super Fighter Pads | NGK Plug Wires | 6-SMD Red Interior Map Lights | Honda S2000 Gearknob Coming SUPER soon: HIDs (Freight Container Arriving Soon) | Front/Rear Strut Bar | Exedy Stage 1 Sports Organic Clutch | Exedy Lightened Flywheel Coming soon: F2 Supercharger kit | F2 Header | Custom 3" Catback Exhaust System with High Flow Cat | Complete Haltech Tune |
#2 (permalink) | |
QUOTE (ttshark @ Oct 27 2009, 05:56 PM)
make some measurements and all i have to say is good luck
2006 Onyx Black MTX 6i its got some rims and some blacked out stuff.. |
Nice wheels but they are not gonna fit, unless you do some crazy rolling and pulling of your fenders lol...
2006 Mazdaspeed 6 sport - Whitewater Pearl Engine & Drivetrain:COBB AP (stage 2+TIHS 93 FMIC), COBB SRI kit (AEM dry flow), COBB MS3 shifter weight, F2 BSD kit w/PTP tray, ATP catless downpipe, Vibrant performance HF cat, Custom FMIC, Denso 2-step colder plugs, Speedies Inlet Pipe kit, HKS SSQV (black edition), SU shifter bushings, SU rear motor mount, AWR transmission mount, AWR passenger side mount, TWM short shifter stage 1, Magnaflow exhaust, Aero Turbine resonator, Corksport muffler hangers, Top Fuel oil catch can, NRG grounding kit, Mazdaspeed oil cap, BLITZ rad cap / Suspension:H&R coilover kit, Megan Racing H-brace, GT spec trailing arm brace, Corksport front strut bar, Corksport trunk brace / Brakes f)EBC greenstuff brake pads, Stoptech slotted rotors, Techna fit brake lines, Žstock / Wheels & tires:League WKR-1 18x8 et 40, Kumho ASX 225/45-18 / Interior:Auto Exe buckskin wheel wrap, Corbeau A4 seats, Corbeau sliders, Audiolink Ipod adapter, Cable jive iphone 3g converter, Prosport boost gauge, RECARO child seat, Pre-amp+EQ by 808speed6, Apex'i mount bracket (AP) / Exterior:Smoked side and rear marker lights, flat black OEM grill, VG shark fin antenna, 35% tint all around, Carbon mirror covers / Lighting:HID 6000k low beams, HID 6000k 55w fog lights, LED brake, reverse and rear signals... Fluids:ENEOS synthetic oil 5w40, Amsoil DOT4 racing brake fluid, Royal Purple (drivetrain)... You can always rely on an ignorant person to be ignorant cause im not asian lol... |
yea its not the caliper you have to worry about its your fender eating the tire (or vice versa)
low offset, closer to 0 and the negative range stick out further and have a deeper dish around +42 offset starts getting unconfortable for most, with having to roll and pull. im running a +35 offset with a 18x8....
![]() 2007 Cheezburger - Ti Gray
#5 (permalink) | |
QUOTE (ttshark @ Oct 27 2009, 08:56 PM)
The more immediate concern would be fender rubbing. What size tires do you intend to run? With a 9.5" rim width, I'd assume something 255mm or wider. Those sorts of widths combined with a +35mm offset will almost certainly lead to fender clearance issues. Rolling the fenders may help, but I wouldn't be surprised if these won't clear even rolled fenders. Make sure you find out the hub bore of those rims. The Mazda6 is 67.1mm. If the rims are larger, you can get adapters to fill in the difference. If the rims are smaller, your best solution is to have the rim hubs machined.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
Not a chance on the rears.
You'll be pulling your fenders and cursing the whole time.
04' 6s MTX sedan - Tein - TC Sportline - Seibon - AEM - Magnaflow - Cusco - Streetglow - Momo - iRotors - Hawk Performance - Maxcar - Ignited - Exile - American Bass - Legacy - TenzoR - Falken - Redline - TWM - Compustar - Racing Beat - AWR - Autometer - Lotek - AutoExe - Megan - Feather Carbon - Autolumination - Wedge Engineering - Scroth - Sparco - Sabelt - NRG - DG Motorsports - Carbon Creations - Cordova Motorsports - Sniper Tuning - Axxess - GT Spec - Tanabe - CP-E - Scangauge - Steeda - Hella - Aero Catch - ELF Racing - Stoptech - Car_LED - ARP - Project Kics
#7 (permalink) | |||
QUOTE (bmorrisj @ Oct 28 2009, 12:38 PM)
QUOTE (jd42 @ Oct 28 2009, 12:38 PM) Quote:
QUOTE (Egierda @ Oct 28 2009, 12:42 PM) Quote:
#8 (permalink) |
Dropping your car will only increase the frequency of rubbing...it won't suddenly cause it to rub if you weren't rubbing in the first place. Even at stock ride height, if the suspension gets compressed enough, yes..you'll rub heavily. I guarantee it.
#9 (permalink) |
i hope youre planning on lowering your car otherwise it will look horrible. get stiffer suspension (springs/shocks or coilovers) to reduce your suspension travel so you dont rub (as much)
#10 (permalink) | |
QUOTE (Egierda @ Oct 28 2009, 04:28 PM)
Another two questions. Being full alloy, are these Rota wheels considered "light weight" compared to others? They wouldn't be like the gram lights, but close perhaps? And finally, if I run on 17x9.5 instead... (if that exists) would this drastically reduce the chance of rubbing? Edit: If I get these I will also be getting BC Racing Coilovers.. so yes it will be lowered
