Old 10-11-2009, 12:50 PM   #1 (permalink)
Toadster's Avatar
Send a message via ICQ to Toadster Send a message via AIM to Toadster Send a message via MSN to Toadster Send a message via Yahoo to Toadster
Thumbs up
will they fit with stock height?
I have an opportunity to get a set of 4 with tires for $425!!!
2004 Performance White MAZDA6s MTX
Injen CAI | Magnaflow Catback | CP-E MAF-c | 18% Tint | Red Line MT-90
17x7 Kosei T1 TS wheels & ContiSportContact 3 225/45-17
My Mazda6 PICS|Toadster's Website
Toadster is offline   Reply With Quote
Old 10-11-2009, 01:12 PM   #2 (permalink)
Yeah they'll fit no probs!
boothy is offline   Reply With Quote
Old 10-11-2009, 01:28 PM   #3 (permalink)
Send a message via AIM to Sokool
Running the same dimensions slammed and all is well.
Sokool is offline   Reply With Quote
Old 10-11-2009, 01:50 PM   #4 (permalink)
jd42's Avatar
QUOTE (boothy @ Oct 11 2009, 01:12 PM)
Yeah they'll fit no probs![/b]
I would suggest a bit more caution with a +42mm offset. Remember that each car can be different due to manufacturing variances in the body alignment.
Rule of thumb on the Mazda 6 is anything below +50mm might encounter fender clearance problems. A +45mm offset can often work with rolled fenders. I would guess that these rims will probably need a fender roll. You may get lucky and be fine with no modifications, but I'd be prepared to roll the fenders just in case.
2006 Mazdaspeed6 GT
Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door
Vist My Garage to see modification list
"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."
Old 10-11-2009, 02:12 PM   #5 (permalink)
I guess I didn't realize he was rocking a 6s. The fenders on a MS6 are known to be wider. So you may need a minor roll of the fender more specifically the rears.
Old 10-11-2009, 02:23 PM   #6 (permalink)
Toadster's Avatar
argh... what a sweet deal, 4 rims + tires for $425
I just bought a new set of 17" tires for my Kosei's... ahh!
if anyone wants on this ad - here it is... http://sacramento.craigslist.org/pts/1412724806.html
Old 10-12-2009, 06:39 PM   #7 (permalink)
pray4mojo's Avatar
QUOTE (jd42 @ Oct 11 2009, 10:50 AM)
Rule of thumb on the Mazda 6 is anything below +50mm might encounter fender clearance problems. A +45mm offset can often work with rolled fenders. I would guess that these rims will probably need a fender roll. You may get lucky and be fine with no modifications, but I'd be prepared to roll the fenders just in case.[/b]
Offset means absolutely nothing without knowing the width of the wheel. I could have a +40 wheel that fits without problems and a +60 wheel that wont fit at all.
Depending on the size of the tire you put on them, you may or may not need to roll. They will definitely fit if you do decide to roll.
QUOTE (Sokool @ Oct 11 2009, 11:12 AM)
The fenders on a MS6 are known to be wider.[/b]
Based on all the wheel fitments I've seen over the years, I would have to say thats wrong.
2006 Onyx Black MTX 6i
its got some rims and some blacked out stuff..
pray4mojo is offline   Reply With Quote
Old 10-12-2009, 06:54 PM   #8 (permalink)
jd42's Avatar
QUOTE (pray4mojo @ Oct 12 2009, 06:39 PM)
Offset means absolutely nothing without knowing the width of the wheel. I could have a +40 wheel that fits without problems and a +60 wheel that wont fit at all.[/b]
That's why I stated "rule of thumb". I was taking the stated 225/40R18 tire size as a given. I guess I should have explicitly included the assumption of "reasonable" tire widths with the rule. You are correct that running very narrow or very wide tires will affect the range of offsets that will work.
2006 Mazdaspeed6 GT
