So my girlfriend took her car in today to get her oil changed, when she went to pick it up they told her all of her tires where over inflated by 70psi. She is running perelli p zero nero's and they said they should be inflated to 30 psi (which sounds about right). My question is, is it really possible to over inflate a tire by 70 psi and drive around on it for about 3,000 miles without it blowing out? I guess we need to talk to her mom's boyfriend who inflated them last. More so just a curious question, thanks guys!
Mods: Seibon TM Carbon Fiber Hood, B&M Transmission Cooler, Tein H Techs, 6000k apexcone hid, AEM short ram intake, f2 step header, optimized throttle body, Magnaflow Catback exhaust, spin-on coversion, BSD, oil pan baffle, racing beat rear and front sway bars, awr front endlinks, racing beat rear endlinks, debadged, audiolink ipod, accolade grill, cx-7 antenna, advance timing mod, steeda throttle body spacer, street unit wishbone mount, awr passenger side mount, awr transmission mount, blacked out rear reflectors, smoked side markers, blacked out headlights, scan gauge MY GARAGE |
I doubt it is possible to over inflate to 70psi and ever more to not notice it
I usually overinflate to 40psi when I go to the track and believe me I notice a lot The comfort is all gone as the tires don't absorb any road imperfection, it is all transmitted to your back. I can't believe someone could inflate a tire to more than 50psi without realizing! |
04 blazing copper mazda 6s mtx apexcone 10k hid low beams, airbox mod, magnaflow cat back exhaust, car-led tails, MSDS headers, PC680MJT battery, CPE Battery tray,SU street RMM, throttle controller, prosport 52mm A/F guage on the way, saving for cpe cai. |
Yeah I'm kinda thinking the tech at the oil change place read it wrong not sure though. She drives pretty aggressively and I would think something would have happened to those tires by now if that was the case.
#5 (permalink) | |
QUOTE (osajek @ Oct 5 2009, 08:11 PM)
Are you sure the tech didn't say the tires were overinflated by 7psi? That's a lot more plausible.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
The tech probably meant. Overinflated to 70psi. My ASX's are 44psi IIRC . I doubt as well the tires would fare very well for long if at all with 100 psi.
The only Good is Knowledge, the only Evil is Ignorance. - Socrates |
#7 (permalink) |
That's unbelievable. Hopefully, that was a verbal mis-communication because I don't see how that would work out at all. I get scared seeing even a number like 35 psi when I'm inflating my tires... hahahaha. I tend to keep mine around 32.
- Matt 2006 Mazda 6i Sport MTX - Mazdaspeed CAI - Mazdaspeed aluminum pedals and footrest - black leather armrest w/red stitching www.myspace.com/adaliepa |
#8 (permalink) | |
![]() Join Date: Feb 2008
QUOTE (jd42 @ Oct 5 2009, 06:24 PM)
