Old 06-04-2009, 04:07 PM   #1 (permalink)
Can someone tell me what the lug nut torque should be for the Mazda 6 GT Wheels (18")?
2007 Bright Island Blue Mazda 6s GT
es99cobra is offline   Reply With Quote
Old 06-04-2009, 04:12 PM   #2 (permalink)
BlackCherry06's Avatar
Send a message via Yahoo to BlackCherry06
85 ft/lbs for nearly all aluminum wheels.
___ ___ ___ ___ ___ ___
BlackCherry06 is online now   Reply With Quote
Old 06-04-2009, 04:27 PM   #3 (permalink)
cool, much obliged! Can't believe it is not in the manual. Looked all over for it. Guess they expect you to take it to dealership.QUOTE (BlackCherry06 @ Jun 4 2009, 03:12 PM)
85 ft/lbs for nearly all aluminum wheels.[/b]
Old 06-04-2009, 08:29 PM   #4 (permalink)
jd42's Avatar
QUOTE (es99cobra @ Jun 4 2009, 04:27 PM)
Can't believe it is not in the manual. Looked all over for it.[/b]
Check the section on changing a flat tire. That's where it is listed in the MS6 owner's manual.
