Hi -
I am new to the forum, and have done several searches, but I still have an unanswered question if this will work or not. (If this has been covered please excuse the duplication) My 2009 Mazda6 GT V6 has 18" rims from the factory.....does anyone know for sure if 16" steel rims will work on the car for winter tire use ? (I know overall diameter can be worked thru tire sizes). My concern is whether the 16 inch rims will interfere with the brake assembly. (I have a set of winters already from my previous car in 16 inch Rims). Has anyone tried this application ? Thanks ! |
![]() Join Date: Apr 2005
According to Tirerack, the stock 6 comes with 16" steel rims with OEM 205/65-16s, so I'd think that your 16" rims would work, as long as you go with the correct tire size.
Oh, and to the 6Club!
#3 (permalink) | |
Thanks for the reply and the welcome !
This is really a complicated area !! There are several models of the car this year - mine actually has stock 18" wheels - the tire rack link for the one I am asking about is: http://www.tirerack.com/tires/SelectTireSi...s+Grand+Touring I have since figured out that my existing winter rims are a 5-115 bolt pattern, and the darn Mazda6 has a 5-114 bolt pattern (grrr)....and apparantly that one millimeter difference means I can't re-use my winter rims. (Unless someone here can inform me otherwise!) QUOTE (Mz6GreyGhost @ Mar 31 2009, 11:44 AM) Quote:
#4 (permalink) | ||
QUOTE (pkfk13 @ Mar 31 2009, 03:05 PM)
QUOTE (pkfk13 @ Mar 31 2009, 03:05 PM) Quote:
#5 (permalink) | |
QUOTE (Mz6GreyGhost @ Apr 1 2009, 03:40 AM)
I *think* that the .5 millimeter is going to screw up my plans to re-use those rims for winter on my new Mazda6 and I will end up having to buy new steel 5-114.5 rims for the winter, rather than keep using my old ones from my Grand Prix.
They don't have different brakes for the 4 and V6, they both have the same(which are actually basically the same as the first gen's).....just make sure overall diameter is the same so your speedometer isn't wrong.
The Xbox 360, however, has set out to put all previous console gremlins to shame. Among the many 360s in IGN offices and homes the failure rate has been staggering and the replacement process long and aggravating. - IGN, April 28, 2006 2009 Mazda 6s Touring - Onyx 2009 Toyota Corolla S - Classic Silver Metallic (Wife's Car)
#7 (permalink) | |
Stock 16" steelies will fit. Beware, however, that if you get the wrong offset (e.g. wheels belonging to an entirely different brand with too low an offset), you might get rubbing issues. A set of stock wheels (steel or alloy) or similar should do you good. 235/55R16 should fit fine on a wide-enough alloy (about 7"), but will be too wide for a 6.5" steel rim. In the latter case, you'll be just fine with 215/60.
QUOTE (pkfk13 @ Apr 2 2009, 04:23 AM) Quote:
Shady I drive too fast to worry about cholesterol. My CarDomain corner 2009 JDM Mazda 6 2.5 MTX #1 (Most people are mediocre by choice. I'm not most people.) 2009 JDM Mazda 6 2.5 MTX #2 (A fool and his money - but it's still his money.) 2008 Mazda Miata (Nothing else matters.) 2005 Mazda 6i MTX (V8s are for the small of mind and short of dick.) 2005 Mazda 6i ATX (Sold. Thanks for the memories!) 1987 Mercedes 300E (Sold. They sure don't make'em like they used to.) 1992 GMC Typhoon (Sold for a song. A lost cause.) 2004 GMC Yukon (Sold. Enough said.) 1991 Mitsubishi Lancer 1.5 GLX-i sedan (Mom's. Don't ask.) 1982 Talbot Alpine (Sold after 23 years. Boy was she a tough MoFo!) |
