Regional Moderator
In the past few days, it has been snowing a lot here in the Pacific Northwest, which is really rare. So as a result my car an '06 6i has been sitting in the carport because I have performance tires on MS6 rims that don't do well in the snow/ice. I've been reading some of last years posts on snow chains etc... but it doesn't look like anyone has found a good solution yet for traction in snow and ice.
Here's my problem: I could use an autosock or a goclaw, but then I can't drive on dry pavement, which would be a problem since some roads are covered in snow and/or ice, while most roads are completely or mostly dry. So I would have to take them off when ever I turn onto a dry road. The other thing is that I don't need studded tires since it doesn't snow that often here, so spending money on those tires would not be worth it. I'm kinda leaning towards getting a set of winter tires, but I don't know how well they perform in the rain, compared to snow and ice. Right now I need a tire that will be used 70% of the time in the rain, 10-20% on dry roads and 10% in snow/ice. Sorry if some parts of this post don't make sense, I haven't had a lot of experience with this kind of weather and what you need to do to prepare your vehicle, also I just spent 9 hours outside in sub 25 degree weather today and my brain and body is still a little numb.
Pacific Northwest Regional Moderator 2006 Redfire metallic Mazda6 i MTX MODS: MS6 rims, JDM Atenza badge, PIAA lights, Pilot fogs, custom L.E.D 3rd brake light, white L.E.D license plate lights, red L.E.D interior lights, Peripheral ipod adapter, alpine speakers, custom made shift knob, dead pedal and heel plate. Eeeww you got Ford on my MAZDA! |
you could always get all-season's. My eagle F1's so far are doing pretty good in the snow here in VT and are fantastic in the rain and dry pavement. If you do decide to get winters instead of switching them back and forth why not put them on steelies for an easy switch and will save your rims.
06 MS6 VRM PG SRI, PG TIP, TurboXS RP, CP-E 3" single exhaust, Forge BPV, TWM Stage 1, Prosport Boost gauge in a Block8head Pod Future Mods- AP, TMIC, 1 step plugs |
Find a price range that you want to work within and go from there.
My discontinued Blizzak WS-50s (replaced by the WS-60) has had excellent response and grip in dry and wet conditions. They handle snow and ice pretty well too, though not as good as other tires can, of course, so I'll be getting a really, really good tire next year, hehe. But I'd really recommend a winter tire so you're less worried about that 10% of time in snow or ice and have greater control. There's absolutely no substitute for having a shorter braking distance with tires that can grip in situations you're not accustomed to. Remember, just because it doesn't happen that often doesn't mean that you should think any less of it---hell, much the opposite, in my opinion.
![]() Now rocking a 91 Miata |
#4 (permalink) | |
QUOTE (nxtlevelmazda6 @ Dec 17 2008, 04:35 AM)
If you decide to run a second set of seasonal tires, using a separate set of rims is the only way to go in my opinion. You avoid the bi-annual costs of re-mounting and re-balancing and have the convenience of swapping wheels/tires in your own driveway instead of waiting for a tire shop to be available.
2006 Mazdaspeed6 GT -- Black Cherry Mica, White/Black Interior, Moonroof, Compass/Auto-Dim Mirror, Satin Aluminum Fuel Door Glow-Shift Boost & Oil Temp. Gauges -- AEM Wideband UEGO Controller -- Slyfex AuxMod -- Denso ITV22 Spark Plugs -- CX-7 Antenna -- Redline Tuning QuickLIFT Mazdaspeed RX-8 Shift Knob -- TWM Short-Throw Shifter -- Speedie6 Turbo Inlet -- CP-E/HKS BPV Kit -- CP-E XCel Intake -- CP-E Turbo-Back Exhaust Car Chemistry Insert -- CP-E Engine & Rear Diff. Mounts -- Turbine Tech Diff. Mount -- Techna-Fit Brake Lines -- StopTech Slotted Rotors -- EBC Redstuff Brake Pads SPC Adj. Ball Joints -- RPM K-Spec Lowering Springs -- KONI Sport Adj. Shocks -- Rota SubZero Wheels -- Goodyear Ultra Grip Performance Tires<span style="color:#2E8B57">"AWD Driving: This vehicle has not been designed for the purpose of off-road driving or rallies. Do not attempt to drive over uneven or rocky surfaces, or across rivers."</span> |
I'm having a similar problem, I have tires that are terrible on snow (purely summer), but I don't really have the money to be buying an exra set of wheels.
Do snow tires really help that much? I don't know anything about car tires. Feel free to enlighten me please. Should I get some all seasons instead of snow tires?
2006 MAZDASPEED 6 is no more... :..( PARTING OUT!!! FOR SALE!!! SM Stage II OCC ($150) DashHawk ($225) |
For OP, I'd go good all seasons, 205-60-16 with 6.5" steelies, or 5 spoke mazda3 16" alloys for looks. Just going 205-60's would make huge improvement with same tire design due to narrow contact patch.
Good option 4 u, imho: http://www.tirerack.com/tires/tires.jsp?ti...uranza+Serenity
04 6S atx hatch 93 RX-7, 75 Trident |
#7 (permalink) | |||
QUOTE (nxtlevelmazda6 @ Dec 17 2008, 01:35 AM)
QUOTE (nxtlevelmazda6 @ Dec 17 2008, 01:35 AM) Quote:
Here's the problem: No matter what tires you have on your car, no matter how good your traction, you are not the only car on the road. Three out of the four accidents we witnessed today involved a vehicle that was stationary when the idiot ran into it. So far as I have been able to determine, no tire on the market protects you from other drivers who are complete Neanderthals. When it snows on our hill, we just suck it up and keep the car in the garage until clear roads return, just as you have done so far. To date, I have found no better solution to the problem that most drivers in Portland do not have real winter tires, but that does not stop them from venturing out on the roads. Today, I canceled two meetings as a result. I'll make up the meetings at a later date; our Mazda6 is secure and snug. |
#8 (permalink) | |
![]() Join Date: Apr 2005
QUOTE (Jus10 @ Dec 17 2008, 06:53 PM)
Ideally, you want a set of good snow tires with separate wheels for the colder months, and yes, they are a VAST improvement in the cold and snow. I've been using them since I've been driving, and I refuse to tackle a Central New York winter without them. But if money is tight, or snowy conditions aren't as common as they are in NY, a set of all-season tires will do. |
#9 (permalink) | |
QUOTE (Mz6GreyGhost @ Dec 17 2008, 07:46 PM)
#10 (permalink) | ||
QUOTE (Jus10 @ Dec 17 2008, 09:55 PM)
QUOTE (Jus10 @ Dec 17 2008, 09:55 PM) Quote:
Are they the best? No. Will they do the job? Yes. |
