Old 08-18-2008, 03:59 PM   #1 (permalink)
speedie6's Avatar
I think I posted a similar topic, perhaps in another forum. Don't remember. But, the upshot is, anybody have opinions on TPMS products? I'd really like one that the display came in a 52mm round format guage, but, I can't find on like that. Other than that, anybody have opinions on brands or types? Thanks.
2007 Velocity Red Mazdaspeed 6:
From 6club GB's: AWR trans mount & side mount, TurbineTech front motor mount & diff mount, Mrlilguy fuelpump, F2 BSD
From SU: SU rear mmt, SU BOV, SU red hoses (upper radiator, intercooler, recirc), GHL catback, DNP header (ceramic coated), ETS 3.25 TMIC, Perin MBC, Spec II+ clutch, Whiteline sway, HKS TwinPower ignition, 2-step colder plugs, spin-on oil filter conversion kit
From CPE: DP w/cat (ceramic coated), Rear diff mount, guagepod, TowPlate
From Cobb: AccessPort, SRI intake, shifter weight
From RPM: RPM Sport springs, Bilstein Shocks, SPC ball joints, Carbotech brake pads, SS brake/clutch lines, AWR f&r end links
From Corksport: CS shock-tower brace, exhaust hangers
From PT-Performance: windage tray, SST turbo, air intake screen, intake manifold porting/EGR delete/VTCS delete, ProSport guages: boost/EGT/wideband, Stage III Water Injection (pending)
Other mods: Speedie6 Turbo Inlet Pipe, TWM stage-1 SS/bushings, d/s rotors, LED tail lights, Enkei RPF1 wheels
Audio: All kinds of bad-ass goods.
speedie6 is offline   Reply With Quote
Old 08-20-2008, 01:51 PM   #2 (permalink)
aviator79's Avatar
I would love to run a TPMS myself. I am lazy.
RENT FENDER ROLLER</span>
