Old 08-15-2008, 04:22 AM   #1 (permalink)
speedie6's Avatar
I've read some of the sticky threads, at least portions of them. I haven't read every part of every sticky. But, basically, I'm aware that the stock wheels on a Speed 6 are 18 x 7.5 offset 55. Generally, if you get wider wheels, you need to decrease the offset, I believe. So, the question is, what would be a good width, offset? I have on my car some crappy chrome peeling and rusting steel wheels -- I didn't know what I was doing when I bought them. But, at least as far as fitment, they seem fine, I've had no rubbing. The vendor said they were 8.5" wide, I don't know the offset. I'd have to measure to be sure, perhaps vendor lied. But I'm sure they are at least 8", they are wider than stock.
So, when I get some better wheels, if the fitment is about the same as what I got, that would be great. I'm running 225 wide tires now. Perhaps might go with 235's next time, not sure.
So, I went looking for possible forged wheels that I might could get. I found some that are actually listed for the RX-8. They are Gram Lights 57F forged 18 x 8.5, 40 offset. Opinions?
I don't mind getting my fenders rolled if I need to, but, so far, I haven't needed to. I have RPM Sport springs, which only slightly lower the car.
2007 Velocity Red Mazdaspeed 6:
From 6club GB's: AWR trans mount & side mount, TurbineTech front motor mount & diff mount, Mrlilguy fuelpump, F2 BSD
From SU: SU rear mmt, SU BOV, SU red hoses (upper radiator, intercooler, recirc), GHL catback, DNP header (ceramic coated), ETS 3.25 TMIC, Perin MBC, Spec II+ clutch, Whiteline sway, HKS TwinPower ignition, 2-step colder plugs, spin-on oil filter conversion kit
From CPE: DP w/cat (ceramic coated), Rear diff mount, guagepod, TowPlate
From Cobb: AccessPort, SRI intake, shifter weight
From RPM: RPM Sport springs, Bilstein Shocks, SPC ball joints, Carbotech brake pads, SS brake/clutch lines, AWR f&r end links
From Corksport: CS shock-tower brace, exhaust hangers
From PT-Performance: windage tray, SST turbo, air intake screen, intake manifold porting/EGR delete/VTCS delete, ProSport guages: boost/EGT/wideband, Stage III Water Injection (pending)
Other mods: Speedie6 Turbo Inlet Pipe, TWM stage-1 SS/bushings, d/s rotors, LED tail lights, Enkei RPF1 wheels
Audio: All kinds of bad-ass goods.
speedie6 is offline   Reply With Quote
Old 08-15-2008, 08:18 AM   #2 (permalink)
Stock rims are 18x7.
2006 Mazdaspeed6 GT - Black Mica/Black w/ sunroof & navigation
Mods - Cobb AP, Synapse BPV, cp-e MS6 Nano, cp-e FMIC, cp-e Turbo Inlet, cp-e Dual Catback Exhaust, TXS Test Pipe, Denso 1 step colder plugs, SU Rear Motor Mount, AWR 88 Duro Passenger Motor Mount, AWR 70 Duro Transmission Mount, RP 5w30 Oil, Amsoil Trans, Diff, & PTO Fluids, TWM Stage 1 Short Shifter & Bushings, Cobb Shifter Weight, VG Shark-fin Antenna, Smoked LED Side Markers, Mazdaspeed Oil Cap, MSD DashHawk, RPM Sport Springs, 225/45/18 Goodyear Eagle F1 All-Seasons
shadesofgray19 is offline   Reply With Quote
Old 08-15-2008, 09:39 AM   #3 (permalink)
speedie6's Avatar
QUOTE (shadesofgray19 @ Aug 15 2008, 07:18 AM)
Stock rims are 18x7.[/b]
Thanks for the correction. Which then has me confused what the heck I do have currently. Given the vendor said stock was 7.5 and said that what he was selling me were 8.5. Was he wrong on both? I guess I gotta measure. But, at any rate, I'm sure that they are wider than stock as the stock 215 tires were notacably small for the wheels.
So, for the wheels I'm looking at now, the 8.5" 40 offset, how's it sound or should I just get 8"?
Old 08-15-2008, 02:13 PM   #4 (permalink)
astlzrMS6's Avatar
Yeah that guy was wrong if you look at the back of the stock rim it says 18x7 with a 55 offset.
8.5 with a 40 offset wont fit unless you do some major work to the fenders. There are a few guys on here running 8.5 with a 45 or greater offset but they had to fully roll their fenders. I've got 18x8 with a 46 offset rims with 235/40/18 tires and they fit just fine. I also rolled my fenders a little but I don't think it was really needed.
astlzrMS6 is offline   Reply With Quote
Old 08-15-2008, 02:40 PM   #5 (permalink)
speedie6's Avatar
QUOTE (astlzrMS6 @ Aug 15 2008, 01:13 PM)
8.5 with a 40 offset wont fit unless you do some major work to the fenders. There are a few guys on here running 8.5 with a 45 or greater offset but they had to fully roll their fenders. I've got 18x8 with a 46 offset rims with 235/40/18 tires and they fit just fine. I also rolled my fenders a little but I don't think it was really needed.[/b]
Thanks. I'll probably go 8.0.
Old 08-20-2008, 01:52 PM   #6 (permalink)
aviator79's Avatar
Roll them and run 245's!
RENT FENDER ROLLER</span>
Old 08-20-2008, 06:46 PM   #7 (permalink)
speedie6's Avatar
Well, I had a real hard time making up my mind what to go with. In the end, I wound up with a pretty conservative width wheel. Its only 7.5. But the wheel I decided on wasn't available in an 8 with a usable offset. Here's the ones I got:
Its not a true forged. There are a couple of wheel manufactures that have their own processes that are supposed to give near-forged strength, but lower cost. And I just love its black chrome.
Now, they have another similar wheel which will be available in an 8", 48 offset, but, its not available yet.
Old 08-20-2008, 09:10 PM   #8 (permalink)
DennisW's Avatar
QUOTE (speedie6 @ Aug 20 2008, 05:46 PM)
Now, they have another similar wheel which will be available in an 8", 48 offset, but, its not available yet.[/b]
It's called pressure casting. Instead of just pouring the molten metal into the mold, it's forced in under high pressure. The injection pressure does away with the problem of porous castings and results in a stronger wheel.
Not that gravity cast wheels are crap. A great majority of the wheels on street driven cars are gravity cast and they hold up just fine. Presure casting is a more expensive process than gravity casting but much less expensive than forging.
Enkei's are very good quality wheels, you'll not have any problems with them.
[b]"There are three easy ways of losing money - racing is the quickest, women the most pleasant, and the Stock Market the most certain."</span>
DennisW is offline   Reply With Quote
Old 08-20-2008, 09:51 PM   #9 (permalink)
speedie6's Avatar
QUOTE (DennisW @ Aug 20 2008, 08:10 PM)
Enkei's are very good quality wheels, you'll not have any problems with them.[/b]
They were SOMEWHAT less than forged, but not a LOT less than forged, depending on exactly what forged wheel it is compared to. But, I didn't find any true forged with that kind of black chrome finish. They are really beautiful wheels.
What I would have found 'ideal" was that style or similar, true forged, 8" wide, 50 offset. Didn't find it. Probably would have cost a lot more if I did. So, these may not be "ideal" but, they do kick ass.
Here is a picture of an upcoming Enkei model, that is going to be available in 8" wide 48 offset, but can't get it yet:
Old 08-28-2008, 01:11 AM   #10 (permalink)
Glocker23's Avatar
I rally like those metallic silver ones on the left. I would def throw those on my car.
2006 Liquid Platinum Mazdaspeed 6 GT
Shark fin antenna, led clear corners, smoked rear led reflectors, PIAA Extreme White Highs/fogs, CPE CAI, Powder coated stock MS6 Wheels, TWM Stage 2 STS, CPE Catted DP, Auto Exe TMIC & Cobb Inlet Pipe.
Glocker23 is offline   Reply With Quote
