True..
![]() They are dirty yet yes ![]() The ones I found on Ebay.. They are 18X7.5 with offset of (+50) Actual price for them is 2700$.. wow 8D I bought them badly used with 250$ with no center caps or tires But what confuses me is that it's written (casted) on one of rays at all the wheels at the inner side "R-1 Racing Speed" My question here, what the hell is going on? They are Volk GT 7, but what makes them R-1 Racing Speed brand? Another thing, I tried to fit in one of them in a lovely 115F' morning, but the oem lug nuts didn't fit.. Do I need long super lightweighted lug nuts? I mean, I do need ones, but where to get them 8D? ![]() those two images explain them ![]() ![]() Just notice how tight the lug nuts holes are compared to the oem wheels. What the hell is going on here too? I plan to forge the damaged wheel, and paint all of them in not reflective white to give it a race car look 8D, suggestions? Since the black and chrome lip combination make the wheel looks smaller than the 17 oems..
unfortunately i don't understand the question, so i can't answer it?
BUT, in regards to the lugs, in many case you'll need to use some sort of tuner lug for aftermarket wheels. doesn't have to be lightweight or long or open ended, just a thin spline drive will be fine.
The 2 pics of the 4 wheels each are different wheels. It doesn't look like you got Volks for $250. It looks like you got Volk knock-offs (used at that) for $250. It's possible that Volk might have had several versions and those dusty wheels are one of the real versions, but R1 Racing makes knockoffs.... and the identifiers that are cast seem to indicate knockoff as well.
L76-powered |
I have volks on my Z. Look inside the rim, you should have a tag in there stating the production date, offsets, and specs.
Here are mine. ![]() If you don't have them, sorry they are knock offs w/ Ebay Volk Stickers. If its too good to be true, it probably is. Volks beaten up still can fetch over a grand easily.
![]() Built Motor 344/356 |
