Anyone ever try the NITTO INVO tires? opinions?
And can we get an 8inch wheel to work for the MS6 without any rubbing on the inner strut/shock mounts?
2006 MS6/Sport, Black Mica Exterior: Sharkfin Ant, Llumar full front Body Armor, Motegi DP6 wheels w/Nitto INVO's 235/40/18, Techna-Fit SS Braided Brake Lines, AWR Front&Rear Endlink, AE FSB & RSB, K-Sport Kontrol Pro Coilovers, SPC Camber Adj. Ball Joints, Chromed AE Front Strut Tower brace. Interior: Redline Shift boot, AE Silver CF shiftknob, TWM Short Throw Shift kit, Dynamat Stinger kit, Lotek gauge pod w/VEI guages, Oil psi, Oil temp, Boost, Autometer Sport-comp wideband A/F. Engine: CP-E Standback, CP-E FullControl™ Flash, CP-E CAI, CP-E DP, CP-E TBE, CP-E Rear Engine MM, CP-E battery tray, Protege'garage rebuilt K04Turbo, High Flow 3" Turbo Inlet Pipe, SU Odyssey PC680MJ Battery, Chromed Valve cover, Chromed front Cold pipe, TurboSmart Dual Port BOV, Anodized/Blue fluid Caps,. |
nitto I know nothing about, except that they do not make a max perf summer tire but im looking at getting the Sumitoma HTR Z III. Cheep MAX Performance Summer tires. $155 each!
And 8" will fit with proper offset...about 48. Lower offsets may require a roll dependent on tires you run. You need to research this more as there is a lot more to a wheel than its width. i.e. bolt patter, bore size and offset.
RENT FENDER ROLLER</span> CPE Standback - CPE catted DP to dual muffler CS mounts - CPE FMIC w/ OEM air dam & HKS BOV - mrlilguy CDFP - D N <span style="color:#4b0082">P - CPE CAI - speedie6 TIP - SU MM - TWM SS - TT Front MM - TT & CPE Rear Diffmounts - BC Coilovers - Brembo Front/StopTech & EBC Redstuff rear - F2 Baffle <strike>BS</strike> - <strike>VTCS & EGR</strike> - - 8.5x18et45 GM 57F's w/ 245/40 M3s / 18x8.5et45 Advan RZ GM w/ 245/40 Re01Rs - Passport 8500 X50 + LI Quad Laser Jammer - X50 mute button, Sub volume, LI swith & Dashawk custom mounted in steering column - EURO Tails - Rola Roof Rack - Prosport Boost gauge-Vent mount - TSX projector Retrofit - 55w projectors in fog retrofit - Carputer - CRX antenna w/ sat antenna mounted in front - Audison Dynaudio & Alumapro - Amsoil/Schafer Supreme |
