Old 05-12-2008, 07:41 PM   #1 (permalink)
Hostility's Avatar
Send a message via AIM to Hostility
Just wondering. I'm thinking about getting these.
the offset is 45.
they are 17 lbs each.
5 x 114
17x7
i would be able to put these on my stock tires correct?
then would the offset be okay?
i have tein s-techs and i think 45 is pushin it but im not sure if ill rub
2007 Mazda6i ATX//35W 8000k Apexcone HIDs//5% tint//AEM CAI
Megan Racing H-Brace//Tein S-tech lowering springs//D/S Rotors
Tanabe Concept G axleback exhaust//700w Interfire Amplifier
350w 12" MB Quart Sub//Pioneer Head Unit//18x8 215/40 Nexxen
Hostility is offline   Reply With Quote
Old 05-12-2008, 07:52 PM   #2 (permalink)
threewhistles's Avatar
Send a message via Yahoo to threewhistles
45 is the borderline. Springs will not make your car rub, will only increase the frequency that they rub. Count on needing a roll.
Trust me, your signature is lame. Not only am I president of "The Old Guy Hater Club", I'm a client.
2008 Los Angeles Angels of Fountain Valley: FTL.....(choke, gag, choke)
threewhistles is offline   Reply With Quote
Old 05-12-2008, 07:57 PM   #3 (permalink)
Hostility's Avatar
meaning the more chance of them rubbing, as in over bumps and shit like that?
Old 05-12-2008, 08:02 PM   #4 (permalink)
Correct, they either will rub or they won't. Being lowered will probably cause them to rub more often if they are going to at all.
Old 05-12-2008, 08:12 PM   #5 (permalink)
Hostility's Avatar
i dont get why they would if its stock tires..?
Old 05-12-2008, 08:27 PM   #6 (permalink)
blue06mazda6's Avatar
Send a message via AIM to blue06mazda6
With the lower offset the wheel may stick out past the fender. That will cause it to rub over bumps or heavy loads.
06 6 I| Xm Radio|Stubby Antenna|Silverstar turn Signal bulbs (Front)|6 1/2 speakers in front door|6 x 8 in rear|Wing Spoiler|Black OE Tail lights|4 Brake light mod|Side markers converted to flash|18 x 7.5 MB Boost rims|Remote Start|LED Map and Door lights|Sport Grill|Auto Dimming Mirror| MS Springs| JDM Visors| K & N SRI|Sony HU|12 in. Infinity Sub @ 400 RMS|Removed Door moldings|
Car Pics
blue06mazda6 is offline   Reply With Quote
Old 05-12-2008, 08:34 PM   #7 (permalink)
Hostility's Avatar
totally just thought of that. forgot stock offset is like 60 lol
okay well there's another cheaper option but the offset is crazy and im not sure what to do.
those.
42 offset
17x7
how much rolling/pulling would i have to do?
Old 05-12-2008, 09:31 PM   #8 (permalink)
a 42 offset will stick out farther toward the fender than a 45 offset... you should look for numbers higher than 45 - 48mm, 50mm, 53mm and 55mm are common offsets for aftermarket wheels and should all work with the OEM tire size
you could probably get away with the 45 offset/OEM tires if you roll the rear fenders... plenty of people have done it, and some places even rent fender rollers....
by way of comparison - the Kazera KZ-V that I have for sale are 17x7 and the offset is 50mm and the tires are 215/50-17; my car has Eibach Pro-Kit springs which are close to the S-Tech in lowering and I never had any rubbing... and I can tell you, the streets where I live are not very smooth! Even with four adult men all 200+ pounds in the car, it never rubbed...
2005 Lapis Blue 6s 5-door
2005 Titanuim Gray MVP ES
peteh110 is offline   Reply With Quote
