Old 03-27-2008, 08:58 PM   #1 (permalink)
o4mazda6s's Avatar
Hey guys, just wondering if you could help me out... I'm kind of clueless and I don't know if anyone has the same springs and whatnot as me...
I've dropped my o4 mazda 6 -
1.8 front and rear - sprint springs..
Do you guys know what size tire, rim, or offset could possibly work without rolling the fenders no rubbing.. and everything.. If you don't mind helping...
Thanks.
o4mazda6 v6. </span>
Alpine CDE-9881. 2-12" Diamond Audio. Kicker Mono 750.1.
Sprint Springs 1.8/1.8. Clear Side Markers. HID headlights.
More to Come... More to Change...</span>
My car
o4mazda6s is offline   Reply With Quote
Old 03-27-2008, 09:50 PM   #2 (permalink)
48MM+ offset or greater
18s 17s will fit with a width of 7.5 inches
225/45/18 or 17s will fit
2006 Speed6 GT - Titanium/black leather
RPM Sports/Bilstein HDs:Optima red top:EBC Redstuffs/rotora rotors
18 x 7.5 BBS RGRs Diamond Black with 225/45/18 Continental Contisport 3s (for summer)
Stock rims with 215/45/18 falken ZIEX-912 (for winter)
My other car: 2003 911 Arctic Silver/Metropol Blue interior - Loaded
Want a mod that makes your car faster? Fix the nut behind the wheel.
stout is offline   Reply With Quote
Old 03-27-2008, 10:20 PM   #3 (permalink)
Slapstick's Avatar
play with this, its awesome.
wheel/rim calculator
compare it to the rims and tires you have on now with your drop.
and BTW, I have 18x7.5s, 225/40 tire, 48 offset, with a mazdaspeed hatch spring drop, no roll.
check the forum members wheels section too.
05 6s sedan 3L V6, 6spd Auto, cp-e MAFci, CM Optimized TB, Steeda TBS, M'Speed sway kit, M'speed hatch Springs, RB exhaust, Toyo Proxes 4, and plenty of eye candy.
No Replacement For Displacement.
Slapstick is offline   Reply With Quote
Old 03-28-2008, 07:54 AM   #4 (permalink)
hypnoticblazze's Avatar
check the forum members wheels section too.[/b]
+1
You need to go 48 and up. To be on the safer side I would stick to +50mm offset. If you go below that you WILL have to roll the fender.
2005 Onxy Black 6s
Fujita F5 CAI // Optimized TB // Magnaflow cat-back // 6000k Apexcone 35w HID's in low beams (with glare mod) and integrated fog lights // Piaa clear 194's // Sirius Sporter 5 // Tenzo R's Passion 5 18X7.5 // 225 40 Falken Ziex ZE912 // LED tails // 15% tint all around
hypnoticblazze is offline   Reply With Quote
Old 03-28-2008, 08:08 AM   #5 (permalink)
Iluv2zmzm's Avatar
You need to go 48 and up. To be on the safer side I would stick to +50mm offset. If you go below that you WILL have to roll the fender.[/b]
not necessarily, my wheels are a +50 and i had to roll rears... MS springs which are less of a drop than the Sprint springs...
you probably should just roll them anyway and not have to worry about the wheel size, well almost unless you go to like 19's & 20's
Cardomain Page
6club Garage
Iluv2zmzm is offline   Reply With Quote
Old 03-28-2008, 08:19 AM   #6 (permalink)
you probably should just roll them anyway and not have to worry about the wheel size, well almost unless you go to like 19's & 20's[/b]
+1
I guess its hit and miss huh? Because some members have ran +50 offset with a drop and no problem. Others have had a problem with rubbing. However I do agree with you. Probably safer to roll the fenders anyway.
2005 Onxy Black 6s
Old 03-28-2008, 10:05 AM   #7 (permalink)
o4mazda6s's Avatar
so how do you roll the fenders? i heard you can do it yourself or professionally. how much does that cost? =/
My car
Old 03-28-2008, 10:53 AM   #8 (permalink)
Iluv2zmzm's Avatar
so how do you roll the fenders? i heard you can do it yourself or professionally. how much does that cost? =/[/b]
you can rent the tool and do it yourself or bring it to a local shop which is what i did, they did a great job and actually never heard of it until i showed them, they were amazed at the tool...
i rented mine from Eric at tireswap.com, i think you need to email him and see if there is a waiting list.. i also believe a couple members are renting the tool out...
forgot about this from good ole mazda6tech:
Fender Rolling How To
Good Luck
Cardomain Page
6club Garage
Old 03-28-2008, 11:21 AM   #9 (permalink)
You are also running 18X8s correct? I have 18X.7.5 with a 50MM offset and I do not nor will I ever rub.
Some folks say there is a difference between the M6 & the MS6 as far as wheel fitment but I find it hard to believe.
Old 03-28-2008, 11:39 AM   #10 (permalink)
Iluv2zmzm's Avatar
Some folks say there is a difference between the M6 & the MS6 as far as wheel fitment but I find it hard to believe.[/b]
yes 18x8
but are you lowered?? the topic starter is lowered 1.8 inches
Cardomain Page
6club Garage
