Hi everyone
I am getting rid of my OEM rims and i am search for some new 16" rims why not 17"? because i just change my tires a month ago and they cost me $500 and i found 5zigen rims and they looks hot but the offset is +42 so does anyone know +42 offset will be ok for 16"? I have not drop my 6 yet but plan to do so later those are the rims i am going to get [attachment=34288:untitled.bmp]
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
For example, the RX8 rim R16x7,5 Offset 50mm with 225/55 rub a little in the rear with passenger in the rear seat with Eibach. A 225/50 fit better
Stock R16x7 Offset 55mm with 205/55 fit perfectly (an Eibach Pro Kit) Just an idea I think with 42mm you will have to roll your rear fender.
Mazda 6 (2.0) Automatic. Strato Blue Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs). 2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
#3 (permalink) | |
I have to agree, but since your car is not dropped, i don't think it's gonna be an issue if you're not driving anyone around or lugging alot of weight. I have 16" rx7 +50 offset wheels with 225/50/r16 tires and they rubbed right off the bat with 4 adults, however, my car was dropped 1" in the rear.
![]() redfire metallic 03 6s MTx + Exedy CP-E + Koni's + Megans + TWM + lightweight 16x8 JDM Shoes FTW!!! CarDomain Stock Parts FS Here |
I have the 16" RX8 wheels, not lowered, and didn't have a rubbing issue even when I loaded up a rear corner. However, if I had been lowered, no doubt there would be rubbing. With the stock 205/60 Michelins on the RX8's, its a little better, but still pretty close. You should get away with a +42 offset with stock size tires and a fender roll, but its questionable after that.
'06 6i driver |
