i know im crazy, but let's lay down what im looking at,
im only concerned about the rears work vs-xx 18x9 +56 ok, with that said, i KNOW these are hella cutting it close to impossible. but given a relatively high offset for a 9", it might work with the correct tire. that's question 1, discuss. i was thinking 225 with maybe a lower profile tire, and use 35 instead of 40, which leads into question 2... question 2, i know recommended load index for the 6 is 91+, but technically, wouldn't i still be safe with a tire that has a lower load index given that i (me, myself) weighs about 110lbs, and usually dont carry any passenger? can i scrape by with say... a 87? i know a buddy of mine is running 88 (has been doing so for almost a year now) on his 6, and it's fine. please help, anything is appriciated. edit: after thinking some more, do you guys think i'll have problem clearing the INSIDE against the arm? that might be the bigger problem than fender clearence.... edit2: yeah, the fender should definately clear, im more worried about the inside, maybe a 1/4in spacer? |
#2 (permalink) | ||
And this doesn't even take into account that the tire you're considering is over an inch smaller than the factory size (4.2%). The max smaller you should go is 2%. I don't understand why you're even considering this.
