Old 10-10-2007, 10:48 AM   #1 (permalink)
Fenixz Prime's Avatar
Arrow
So, I decided to get bigger rims for my car. Got myself a set of used 18" m20 which came from a 2006 civic. So got home and installed the rims. Test drove and I started to hear this humming sound coming from the front, so I took the front rims again and re installed it only to make the sound louder. I was looking at the rims and how the fit the car and seems like it doesn't fit tight on the car. I'd say a few millemeters. I tried to center the rim which I thought might fix the problem but haven't gotten it quite right.
Has anybody had this type of problem? Also another thing i was considering as an issue was that I am using the original lug nuts and not the skinnier tuner lugs. Could that be the issue? Theres definitely no rubbing as I haven't lowered the car yet. I'd appreciate any input in the matter. Any suggestions on how to fix?
Thanks.
Pictures of my 6 soon to be posted here. It was supposed to be done months ago.
Fenixz Prime is offline   Reply With Quote
Old 10-10-2007, 11:12 AM   #2 (permalink)
ZoomZoom04's Avatar
Send a message via AIM to ZoomZoom04
Is the bolt pattern the same? Ours is 5 X 114.3
Also, the lug nuts may need to be different if its a tuner wheel or something... I know some have a cone shape and others are straight.
Humming can also be the tires.
-Willy-
*Blazing Copper '04 M6i Hatch, ATX*
ZoomZoom04 is offline   Reply With Quote
Old 10-10-2007, 11:21 AM   #3 (permalink)
It is 5x114.3, center bore is a bit wider. If it is the tire, would having it balanced fix the problem? Is there anything i can do to check what the real problem is?
Thanks.
Old 10-10-2007, 11:23 AM   #4 (permalink)
mattman8's Avatar
Send a message via AIM to mattman8 Send a message via MSN to mattman8
Also the tire can rubbing on something
Your Dream girl sitting at the end of the bar is another man's nightmare.
mattman8 is offline   Reply With Quote
