Old 10-07-2007, 09:56 AM   #1 (permalink)
I'm a total noob about tires and sizing. I read the stickies, but I just have one question. I have a 2007 Mazda 6 Sport V6 (stock tires are 215/45 R18). The stickies show that 205/60 R16 would fit the 6, but would it fit a vehicle with OEM 18" wheels?
The size and speed accuracy are perfect between the two sizes listed above, I'm just wondering about the brakes, fitment, etc.
Thanks!
2007 Mazda 6 GT-V6 (Black Onyx)
schrumby is offline   Reply With Quote
Old 10-07-2007, 10:19 AM   #2 (permalink)
jd42's Avatar
Thanks![/b]
17" wheels will fit over the Mazdaspeed 6 brakes, which are larger than the brakes on the Mazda 6, so I assume 16" wheels would fit your car. You can confirm on TireRack's website-- go to the winter wheels+tires section to look for smaller wheel options.
Old 10-07-2007, 11:39 AM   #3 (permalink)
Looking at TireRack, it gives the option of 17" & 16", it just seems too much to go from 18" stock to 16" winter (but again, I'm a tire noob )
Old 10-07-2007, 10:43 PM   #4 (permalink)
5Speed6's Avatar
Looking at TireRack, it gives the option of 17" & 16", it just seems too much to go from 18" stock to 16" winter (but again, I'm a tire noob )[/b]
16" is spot on for winters. Just get one of the cheap tire/wheel packages and store your stock wheels/tires for the season.
2008 Mazdaspeed3 GT
CP-E
5Speed6 is offline   Reply With Quote
