#1 (permalink) | |
Over the years, I have seen many questions come up about whether Altima wheels or Honda wheels will fit the 6. Fitting original equipment wheels from another vehicle manufacturer poses problems not usually associated with aftermarket wheels. Original equipment wheels are bored out to exactly the size of the hub diameter of the intended application. For example, the Mazda6 has a hub diameter of 67.1mm and the center bore of any Mazda6 original equipment wheel is 67.1mm. Some Toyotas have a center bore of 60.1mm. So, while the bolt pattern may be the same, and the offset is good for the 6, the wheel won't fit over the hub because the opening is too small. The question is, where do you go to find that information on other vehicle's center bores and bolt patterns?
I have finally come across a website that provides that information. It is by no means complete, but it contains a lot of vehicles. Please reference this link if you are considering buying original equipment wheels from another vehicle manufacturer. Enjoy. http://www.discountedwheelwarehouse.com/Ve...n_Reference.cfm
Oh yeah baby! Pin this!
2005 Lapis Blue 6s AT Sedan <<<<<<<<<<< Mazda Seatbelt Pads Interest Thread >>>>>>>>> |
Does the center bore only affect the original wheels? Do I have to check the center bore on the after market rims when I look for a second hand one?
Pictures of my 6 soon to be posted here. It was supposed to be done months ago. |
![]() Join Date: Aug 2005
Pinned, my new truck is 6x139.7? WTF~!
2006 Mazdaspeed6 - Grand Touring w/ Moonroof - Black/Black- Click here to see it... 2005 Mazda6s - Fully loaded w/ every option but ATX - Steel Gray/Black (SOLD) - Click here to see it... 2006 Mazda6i - Sport package w/ Bose/Moonroof ATX - Dark Cherry/Black - Click here to see it... |
#6 (permalink) | |
#8 (permalink) | |
QUOTE (Jack ffr1846 @ Dec 3 2007, 07:21 AM)
There have been lots of recommendations about using the 93-95 RX7 rims on the 03-07 Mazda6, so I guess that takes care of this model. |
#10 (permalink) |
you should be able to bore out the center bore shouldn't you? If you can acheive 67.5 with a mazda wheel, you would think that you shoudl be able to obtain it with a toyota or lexus wheel. (Or atleast you would think so.)
