Old 07-31-2007, 12:49 PM   #1 (permalink)
rdandy5875's Avatar
Hey guys, I'm looking to buy a used set of wheels and tires locally. I'm really not current on wheel sizes.
The wheels are KOSEKI k-1's, 17 x 7.5, 114.3 x 5, and the offset is 45. I was wondering if these numbers sound agreeable to the speed6.
They also come with tires 225/45, still in pretty good shape, but I would probably be taking the tires of for a new set.
I really want to get some lighter wheels to reduce the unsprung weight.
Thanks, Randy
Whitewater Pearl - 2006 mazda speed6 # xx4983 Build date : 1/06
emissions recall, clutch tsb, uneven and premature front tire wear problem
smoking at idle problem twice
list your partial vin# and build date in your sig. for reference
rdandy5875 is offline   Reply With Quote
Old 07-31-2007, 12:52 PM   #2 (permalink)
yomama69's Avatar
Thanks, Randy[/b]
Why go to 17's for that? You can get 18" wheels that weigh 18-19 lbs each for a reasonable price. Also the OEM tires are heavy. Tires I put on my car after OEMs were about 3lbs. less per corner.
BMW E90 335i
Titanium Silver Metallic w/ Gray Dakota Leather - Premium Package, Sport Package w/ paddle shifters, Comfort Access, Park Distance Control, Sirius
yomama69 is offline   Reply With Quote
Old 07-31-2007, 12:56 PM   #3 (permalink)
rdandy5875's Avatar
Why go to 17's for that? You can get 18" wheels that weigh 18-19 lbs each for a reasonable price. Also the OEM tires are heavy. Tires I put on my car after OEMs were about 3lbs. less per corner.[/b]
They're local, they're cheap, they're 17 pounds. They have good tires (treadwise) on them that I can sell even if I get new tires, which increases their cheapness factor. And I like the color, like a dark grey.
Old 07-31-2007, 01:16 PM   #4 (permalink)
kurfgator's Avatar
Send a message via AIM to kurfgator
Those should fit just fine. I would sell the tires and go with a 225/50-17. That is only .9% off from the stock MS6 tire size. That will keep your speedo acurate.
2006 Titanium Gray Metalic Mazdaspeed 6 Sport
Parting out my car! South Florida only (don't want to ship and I like cash). I have a lot of stuff. PM me if you are in SoFla and looking for some parts.
kurfgator is offline   Reply With Quote
Old 07-31-2007, 01:21 PM   #5 (permalink)
rdandy5875's Avatar
Those should fit just fine. I would sell the tires and go with a 225/50-17. That is only .9% off from the stock MS6 tire size. That will keep your speedo acurate.[/b]
Thanks. I find the speedo is off by 3-4% with the stock wheels and tires anyways.
Old 07-31-2007, 01:54 PM   #6 (permalink)
mdogg's Avatar
For any given mass, the moment of inertia (rotational mass) is greater for the larger diameter.
Moment of Inertia ("rotational mass") ~ m * r^2
This isn't EXACTLY correct since the wheel's mass isn't completely on the outer diameter.... but it's a good proportionality rule for this.
So even for 2 wheels that both weigh 17 lbs, the smaller diameter one will be slightly easier for the engine to rotate. I think the Kosei's are a good choice! OTOH, I think 18s look better aesthetically. So it's really a toss up IMO - just depends on what you are going for.
Thanks. I find the speedo is off by 3-4% with the stock wheels and tires anyways.[/b]
Could be improper inflation...
L76-powered
mdogg is offline   Reply With Quote
Old 07-31-2007, 02:11 PM   #7 (permalink)
rdandy5875's Avatar
Could be improper inflation...[/b]
I definitley agree that the 18's look better. But I'm throwing aesthetics out the window..
I want something lighter, and less money to replace tires.
If I'm going to eat front tires every 7000 miles, I may as well get 17's. With the reduced weight I should see additional performance benefits.
Also as far as the mileage accuracy, I was using a gps, but I was looking at the speedo, which the needle may not be precise. I suppose for a fair experiment I'd have to use the trip meter against my gps and see if the accumilated mileage differs. I keep my tires at 38.5lbs..
Old 07-31-2007, 08:52 PM   #8 (permalink)
jd42's Avatar
The wheels are KOSEKI k-1's, 17 x 7.5, 114.3 x 5, and the offset is 45. I was wondering if these numbers sound agreeable to the speed6.[/b]
Those are the same dimensions as the wheels I use for winter, so they should fit.
Don't forget to check on the hub bore-- the MS6 needs 67.1mm. The hub bore usually isn't too small with aftermarket wheels, but you might need a set of hub-centric rings if the hub bore is too large.
You also might want to check the rear fender clearance if you stick with the 225mm tires. I use a 215mm section width tire for winter, and didn't have any rubbing problems (this was before I rolled the fenders to fit the summer tires).
