i j/ swapped out my 18" MS6 wheels + 215/45/18 Pirelli P Nero Zero M+S with powdercoated 18" RX-8 + 235/40/18 Falken ZE912
accordin' to my research: MS6 wheels = 23.5 lbs 215/45/18 Pirelli = 23 lbs net total = +/-46.5 lbs RX=8 Wheels = 22.6 lbs 235/40/18 ZE912 = 26.8 lbs net total = +/-49.4 lbs roughly 3lbs gained per corner... i found accelerating is j/ a bit slugglish.....so is it j/ me, or that 3lbs/corner does make a different.... will i see a significant sign of MPG decrease? Pre-mature brake pads? etc? |
#2 (permalink) | |
Could have sworn that the RX-8 wheels were 2lbs lighter (per rim) - would be about the same with the wider/heavier tyres...
AutoExe Replica CF grille, TXS BPV, Apexi SRI, Kings Springs (30mm drop), RX8 wheels or Enkei RPM2 (depending on my mood), SLS test pipe, 3.25" ETS TMIC and my trusty V1 |
i would imagine, as with any additional weight, your accel will dimish.. overall though, you kinda have to decide what you want... i mean your giving up 12 pounds but gaining 20mm of rubber per corner.. if you auto-x this might mean alot. I'm not an avid auto-x'er so I wont begin to get into how 235's are better than 215's and so on and so forth. i'll leave that for one of the experts...
you could always keep the 235's and run some forged 18x8's rims. that would give you the advantage of the 235's and some weight reduction over the stock rims... good luck
2005 Mazda 6i Steel Grey - Magnaflow Catback, Airbox Mod, more to come [x] Cat Back Exhaust [x] Cold Air Intake [x] Non Sport Appearance Package [x] TEIN S-Techs [x] Nex-O M-20's 18x7.5 w/ Yokohama AVS ES100's [ ] Vibrant Header 1991 Eagle Talon TSi AWD - 11.467 @ 121.460 MPH stroked + GT42R [x]DONE!!! |
#4 (permalink) | |
#5 (permalink) | |
#6 (permalink) | |
#7 (permalink) | |
duh, what?!? so a 215 VS a 235 has the same contact area? Oh, please do explain this one in great detail...
2006 Titanium Gray MS6 MB Boost 18" with Goodyear Eagle F1 All Season Dashhawk SPC Balljoints -1 Camber front, -1.5 Camber rear. 0.0 Toe |
#8 (permalink) | |
Or, if you would rather get your information from Mazda6tech.com, see here. |
#9 (permalink) |
i've yet to read the technical babble, but before i do i'm going to write to john force and tell him to run 15x5's out back instead of the usual 15x16's... since it's the same contact patch as long as the air pressure is the same
![]() ok i read the brain smokin techie talk and i've gathered that the contact patch is the same in widths close in size (215 vs 235) but at some point the wide and skinny patch of the wider tire will over come the narrow and fat patch of the more narrow tire... good info post...
#10 (permalink) | ||
