Recently i've been checkin' out Falken-512 225/40/18 on RX8 wheels,
for some reasons, they have these crazy deals on certain falken512, certain size, and the 225/40/18 falls in to the crazy deal catagory. and the 235/40/18 are no-deal....and may risk rear rubbings. nevertheless, my Pirelli Nero M+S was rated 93 Load rating same as the OEM Potenza. but the Falken 225/40/18 are @ 92 load rating...so is this not acceptable? ie; Load index ound(lbs):kilogram(kg) - 92:1389lbs:630kg on Falken , 93:1433lbs:650kg on Pirelli/potenzaplease advice |
using math (don't know if that's how it works or not), that means the front of your car can handle 2778lbs... so if our car weighs 3600lbs, w/ a what, 65% front bias? that's 2340lbs, so i think you're good.
until i guess you pound on the brakes and put like 85% of your weight on your front tires... although i figure the manufacturer of the tires would account for this...
my car... it's not a sleeper... it's sleeping. '06 ms6 gt - the new baby '89 n/a fc3s - the jealous one... with all the goodies... too many to list... on a 6 forum, at least ![]() can people PLEASE start using descriptive titles and descriptions...!! no more threads titled "Damn, not again." or "check this out" or "finally!" or... any other crap like that. PLEASE. |
#3 (permalink) | |
hmmm.... say if i have 5 people in my car avg weighting 150lbs...(750lbs totaled) and if i add that to my car's weight roughly 3600lbs, thats 4350lbs... and 65% of that is 2828lbs, that supposingly won't work w/ tires w/ load index lower than 94 nevertheless, since the MS6 and MZ6 come with EBFD (electronic brake force distribution) will the front bias should be alwayz <50% when hard braking? please correct me if i'm incorrect. |
#4 (permalink) | |
I assume this is a Mazdaspeed, right? In that case, the sticker inside your door jamb probably specifies 38 psi inflation. If so, and if: (1) the Falkens are XL rated, and (2) you want to be sure you are within spec, then simply add a pound of pressure, run at 39 psi, and sleep well at night. |
#5 (permalink) | |
on my MS6, i should put in at least 39psi on a 92W 225/40/18 j/ to be safe? correct me if i'm wrong please~ |
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
That why I always try to check the Load Index and the Speed Rating before buy a new tire. If I can, I prefer to upgrade to a highter load index
Mazda 6 (2.0) Automatic. Strato Blue Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs). 2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
#7 (permalink) | |
If your new tires are 92XL, you will get more load capacity by adding pressure above 38 psi, and a 92XL tire at 39 psi has the same carrying capacity as a 93XL tire at 38 psi. If your new tires are standard load (92 load index, no XL), going from 38 psi to 39 psi does not gain you more load capacity (officially). |
