Old 05-25-2007, 06:14 PM   #1 (permalink)
chuyler1's Avatar
Getting the 18x8 D2s on was a chore. I had to grind down the calipers in the front, taking off about 1/4" of material from the outer edge. Installing the Megans took longer than expected. Getting the spring compressors on and off of the front springs was painfull, especially since we didn't have an impact wrench to quickly tighten the compressors. There was major rubbing in the back. I have removed the wheels 3 times so far to roll the fenders. I think I've got it set now. The Megans, as previously discussed, don't do well under load in the rear. They tuck with a full tank and someone in the back. For $100 what can you expect though? I'll prolly upgrade to RPMs or coilovers when I have more funds. As far as ride quality goes, it basically feels like stock unless you run out of suspension travel. That has only happened once and I used to run out with the stock suspension to...its a dip in the road I usually try to avoid but I had to give it a shot once to test the rubbing.
Anyway, if there are other questions feel free to ask...otherwise here are some photos...
2006 Mazdaspeed 6 / 2003 Protege5
chuyler1 is offline   Reply With Quote
Old 05-25-2007, 06:20 PM   #2 (permalink)
i give it two
bluelion is offline   Reply With Quote
Old 05-25-2007, 06:35 PM   #3 (permalink)
Regional Moderator
Mazda6sMtx's Avatar
You had to shave down the front calipers, do you have any pics of what you had to shave off.
Mazda6sMtx is offline   Reply With Quote
Old 05-25-2007, 07:57 PM   #4 (permalink)
dj petey's Avatar
damn, the dreaded caliper clearance issue. why didn't you use a spacer?
06 Liquid Platinum MAZDASPEED6
Engine: Custom AEM SRI, HKS SSQ BOV, SU motor mount, CPE StandBack, 3” DP back SS exhaust, Susp: Megan Racing springs, SPC adjustable ball joints, 24mm Whiteline Adjustable rear ASB, Wheels: 19” Rays G-Games Wolf-77 2-pc rims, 235/35/ZR19 Kumho SPT, Exterior: VG Sharkfin antenna, Fusion rear bumper, Electronics: Jl audio 250/1 powered, factory sub w/ 1.5 Farad cap, Audiolink usb mp3 player, Beltronics Vector FX-1
Vector FX-1 #'s b4 standback ET: 13.2s, Trap: 105.8mph, 60ft: 1.88s, 0-60: 4.9s, lateral G's: 0.94, braking G's: 0.97
dj petey is offline   Reply With Quote
Old 05-25-2007, 10:04 PM   #5 (permalink)
chuyler1's Avatar
A spacer wouldn't have helped any, these wheels just weren't designed for large calipers. It was about as bad as trying to put a 16" wheel on, but only for the first 2". This photo should clear up what I did...
Me doing the dirty work. B and his wife Jess from NEPOC looking on.
Old 05-26-2007, 12:04 AM   #6 (permalink)
duckie76's Avatar
wow, coming from another velocity mica owner, that looks badass!!! I love the wheels and the drop looks great. I just wish it didn't require so much modding or I would go a similar route. Keep up the good work.
06 mazdaspeed6 sport , build # 2126.
Sharkfin.
Forge BPV.
RX8 Rims wrapped in 225/45's.
Dashhawk
duckie76 is offline   Reply With Quote
Old 05-26-2007, 12:27 AM   #7 (permalink)
anotherM6's Avatar
ROTAS FTW!! drop and rims look great
2003 steel grey mazda6s mtx appearance package
GARAGE
anotherM6 is offline   Reply With Quote
Old 05-28-2007, 08:55 PM   #8 (permalink)
looks good man!!!
2005 MAZDA RX8
2003 MAZDA 6
Mikeluvs8 is offline   Reply With Quote
Old 05-30-2007, 12:48 AM   #9 (permalink)
JDM6's Avatar
Send a message via AIM to JDM6
Thats Hot!! Looks hella mean.
<span style="color:#2F4F4F"><span style="font-family:Impact">Mazda6s 2003</span></span>
Injen CAI w/CP-E MAF | Grill & eyelids | Anzo clearsidemarkers | window visor | Metra kit w/Pioneer DEH-P7700MP | 18"RX-8 rims wrapped w/Dunlop SP Sport Signature l Magnaflows | R1 Concept slotted/cross-drilled rotors | Pulstar | Mazdaspeed | Cordova's Optimized TB | 35% tint |
Coming soon: Tein-H springs, Koni Yellow shocks....
JDM6 is offline   Reply With Quote
Old 05-30-2007, 02:40 AM   #10 (permalink)
FATBOY's Avatar
I too must give you a x2
PORK IS NOT A VERB.
FATBOY is offline   Reply With Quote
