Old 05-15-2007, 06:03 AM   #1 (permalink)
04 mazda 6s wagon-- anyone know the offset for the stock 5 spoke rims on the 6s, also what is the lugnut pattern number for the car?
barrett is offline   Reply With Quote
Old 05-15-2007, 09:52 AM   #2 (permalink)
Elicious's Avatar
Read the FAQ:
The wheel offset for the US-spec 6 is: +55mm - +60mm
The wheel offset for the other 6/Atenza models is: the European Mazda6's 16" and 17" rims come with an offset of +55mm. The bolt pattern is 5x114.3. -- Thanks Driver6 (Thorsten)!
Elicious is offline   Reply With Quote
Old 05-16-2007, 07:22 AM   #3 (permalink)
Read the FAQ:
The wheel offset for the other 6/Atenza models is: the European Mazda6's 16" and 17" rims come with an offset of +55mm. The bolt pattern is 5x114.3. -- Thanks Driver6 (Thorsten)![/b]
OK, I KNOW WHAT THE OFFSET ON WHEELS ARE, BUT WHAT PURPOSE DO THEY SERVE?
Old 05-16-2007, 09:13 AM   #4 (permalink)
skyblue's Avatar
Send a message via AIM to skyblue
OK, I KNOW WHAT THE OFFSET ON WHEELS ARE, BUT WHAT PURPOSE DO THEY SERVE?[/b]
Don't yell. Search.
Wheel/Rim FAQ. Everything you can possibily think to ask regarding stock wheels is here.
skyblue is offline   Reply With Quote
Old 08-16-2007, 12:08 PM   #5 (permalink)
Send a message via AIM to OEMBlackCherry606
Don't yell. Search.
Wheel/Rim FAQ. Everything you can possibily think to ask regarding stock wheels is here.[/b]
is that calculator accurate? i'm kinda scared of buying wheels that are 48 offset, 18 x 7.5 inch wheels...i have my eye on rota torque wheels.
2006 Black Cherry Mica Mazdaspeed 6 GT #4127
HKS Short Ram Intake with Apex'i Power Intake Filter
HKS SSQV Blow Off Valve
Speedies TIP
Blitz BLM Boost Guage, with defrost vent pod and Defi Guage Visor
Autoexe Carbon Front Grill
GHL 3" Catback Exhaust with Resonator
...yes, i'll admit it....I'm a JDM nut...bring on the insults
PICS of Mazdaspeed 3 intake w/ Apex'i filter here: http://forum.mazda6club.com/index.php?showtopic=110303
OEMBlackCherry606 is offline   Reply With Quote
Old 08-16-2007, 12:29 PM   #6 (permalink)
Those wheels are absolutely fine, just need to watch what tire you put on it. I believe you want to go with a 225 series without having to roll fenders. Think that will even work if lowered without a fender roll? I am sure someone will correct me if I am wrong.
2006 Mazdaspeed6 GT - Black Mica/Black w/ sunroof & navigation
Mods - Cobb AP, Synapse BPV, cp-e MS6 Nano, cp-e FMIC, cp-e Turbo Inlet, cp-e Dual Catback Exhaust, TXS Test Pipe, Denso 1 step colder plugs, SU Rear Motor Mount, AWR 88 Duro Passenger Motor Mount, AWR 70 Duro Transmission Mount, RP 5w30 Oil, Amsoil Trans, Diff, & PTO Fluids, TWM Stage 1 Short Shifter & Bushings, Cobb Shifter Weight, VG Shark-fin Antenna, Smoked LED Side Markers, Mazdaspeed Oil Cap, MSD DashHawk, RPM Sport Springs, 225/45/18 Goodyear Eagle F1 All-Seasons
shadesofgray19 is offline   Reply With Quote
Old 08-16-2007, 04:13 PM   #7 (permalink)
LapisLazuli6's Avatar
Send a message via AIM to LapisLazuli6 Send a message via MSN to LapisLazuli6 Send a message via Yahoo to LapisLazuli6
Those wheels are absolutely fine, just need to watch what tire you put on it. I believe you want to go with a 225 series without having to roll fenders. Think that will even work if lowered without a fender roll? I am sure someone will correct me if I am wrong.[/b]
I have 225/40ZR18s on Mazdaspeed OEM rims, also lowered about 3/4 of an inch on Mazdaspeed springs. No fender roll.
-Paul
- 06 Redfire 6i Sport; Mazda6 rear license plate frame, Racing Beat front/rear sway bars, MS6 shocks/struts, Mazdaspeed strut bar, Mazdaspeed springs, MS6 struts/shocks, tinted side markers, Mazda trunk mat, all-season floormats, 35% tint, LED tails, iPod audio link, 4300k HIDs, color-matched fogs, DDE angel eyes, MazdaSpeed CAI, OEM remote starter.
LapisLazuli6 is offline   Reply With Quote
Old 08-17-2007, 01:56 PM   #8 (permalink)
maz-exed's Avatar
Send a message via ICQ to maz-exed
well the offset makes your car look better, that's for sure. That's how I understand it. Cause the stock ones on my 03 Mazda 6 2.3 are +60mm
but my other set have and offset of +40mm (So there is a big difference).
If interested
http://en.wikipedia.org/wiki/Offset_%28wheel%29
https://www.rsracing.com/tech-wheel.html (this web explains it in close details)
maz-exed is offline   Reply With Quote
Old 08-17-2007, 07:22 PM   #9 (permalink)
thefurious69's Avatar
Send a message via AIM to thefurious69
If interested
https://www.rsracing.com/tech-wheel.html (this web explains it in close details) [/b]
wat you mean it makes it look better? the higher the number?
liquid platinum MS6~~~ AutoExe front grill
cp-e CAI~~~~~~~~~~~GTspec trailing braces
VEI blue boost guage~~~CorkSport Downpipe
Ipod audio-link
Cp-e catback exhaust
HID matched fogs
SU motor mount
Turboxs race pipe
cork sport strut bar
SU blue boost tubes
CPE HKS SSQV BOV
thefurious69 is offline   Reply With Quote
Old 08-17-2007, 11:32 PM   #10 (permalink)
maz-exed's Avatar
wat you mean it makes it look better? the higher the number?[/b]
Well the lower the number, the worse it will be, since the stock ones on 6i are +60mm and my other are +40mm. So the +40mm offset would have a bigger area underneath your car,when you gona drive, and it will be a little bit more stable. (+it also depend what tires you got)
So this is +20mm difference. bassicly they stick more to the outside. The tires come righ where the fenders are. So that why I had to take mine off. Until i will get new Spring and shocks.
Like on the +40mm whenever i was driving alone it was fine. But a few times I got 4 people and it rubbed badly. And besides my milage is just under 45000, so it's time to change my shoks.
And since the factory ones cost the same as Bilstein heavy duty, i think I would rather go with Bilstein, or Koni (a lot of people are telling me about them , but they are slightly more expensive).
read the one website that I suggested. And you'll understand what offset means.
