im gonna be purchasing a set of 17" wheels and some toyo proxe's ra1's to run at the track for autocross this summer. i wanna run a 17x8 with like a 48mm offset and some 235/40-17's. anyone on here ever run this combo? i just need to know if they well rub or not.
![]() 2003 mazda 6s mtx:H&R sport springs:18" bronze Work Emotion Cr Kai wheels:Work Wheels blue lug nuts:225/40-18 toyo proxes4 tires:Exedy stage 1 clutch:Cp-e motor mount:Black Racing front lip:Mazdaspeed short shifter:TWM Performance shift knob:Racing Beat front and rear sway bars: Racing Beat rear end links:AWR Racing front end links:Racing Beat exhaust:McCulloch 8000K HID's DM slim ballast yellow HID's for fog lights:Tein hood dampers:Zex nitrous system:Air box mod:Silvia parts front grill and eyelids:Metra kit with kenwood deck:Morel hybrid innovation 6.5" components:Zapco REF350.2 amp:Treo tsx 12" sub:Playstation 2 under the seat:7" lcd screen in the map compartment:25% tint e badged:removed door moldingsmy garage! my cardomain |
![]() Join Date: Aug 2005
You'll be good... those tires are undersized...
What wheels are you looking at?
2006 Mazdaspeed6 - Grand Touring w/ Moonroof - Black/Black- Click here to see it... 2005 Mazda6s - Fully loaded w/ every option but ATX - Steel Gray/Black (SOLD) - Click here to see it... 2006 Mazda6i - Sport package w/ Bose/Moonroof ATX - Dark Cherry/Black - Click here to see it... |
not sure yet, something light weight. a good buddy of mine is a manager at les schwab, so im gonna talk to him and see what he can get me for a good price hahaha. i might just run the 5zigen fno1r-c cuz i can get those for like $150 a wheel.
I run 17x8+45 with 235/45/17 tires. You'll need to roll the rear fenders to avoid damaging the tires, but it will definitely fit.
235 tires are not undersized for an 8-inch rim. They'll provide a good balance between comfort and performance. If you went 245, you'd have a lot more sidewall flex and your turn-in wouldn't be as sharp.
Are you one of our valued, satisfied, and/or devoted customers? -- Get your banner here!</span>[/b] |
#5 (permalink) | |
what wheels are you running?
#7 (permalink) | |
Why would have 245's cause more sidewall flex? isn't the height of the side wall the determining factor to the amount of sidewall flex? btw, i run 235/45-17's on 17x8 +48mm offset. One of the best combo for the 6. It'll fix, but like everyone have already stated, you're going to need to roll your rear fenders.
![]() Philips - CPE - Racing Beat - Koni - Mazdaspeed - SSR - Falken
#8 (permalink) | |
Back to reality: a tire's aspect ratio is the sidewall height divided by the section width. It follows, therefore, that within a given aspect ratio (here, 45-series tires) the wider the section width, the taller the sidewall. |
