Old 03-15-2007, 05:57 PM   #1 (permalink)
I am going to autoX my car again soon. I have recently purchased a set of 18x8 RX-8 wheels with the pilot sport cup tires on them (225/40/18). The problem is that one is corded and I need to replace it. I have a supplier for gently used (if that is possible) racing rubber in this tire, but he only has 235/40 18. Is is possible to set the car up with this stagger? The DSC will be off for auto crossing! Also, should I put the larger in the rear like a RWD? Please help! Thanks
[size=1]06 MS6, Titanium, ATP DP, DSM 1G BOV, Perrin MBC, Stewart Warner Boost/Vac gauge center vent, SU motor mount, TWM shifter + bushings, gutted airbox, RX-8 Wheels w/ 235/40/18=ZOOM ZOOM
hoppercheng is offline   Reply With Quote
Old 03-15-2007, 06:01 PM   #2 (permalink)
Stretch's Avatar
Only if the tire diameters are exactly the same... and if so, you'd want to put the wider tires up front.
Stretch is offline   Reply With Quote
Old 03-15-2007, 06:41 PM   #3 (permalink)
Only if the tire diameters are exactly the same... and if so, you'd want to put the wider tires up front.[/b]
well, 225/40 and 235/40 are not going to be the same, but close. Is the biggest problem the awd being that the drive train needs to spin at the same speed?
Old 03-15-2007, 09:24 PM   #4 (permalink)
Tire Guy's Avatar
You could risk burning up the center differential with the overall diameters not being the same.
My Current Car
My Previous Car Page
_______________
<div class='quotetop'>QUOTE
Old 03-15-2007, 09:45 PM   #5 (permalink)
You could risk burning up the center differential with the overall diameters not being the same.[/b]
oh, ok...that is DEFINITELY not good! Thanks
