Old 02-04-2007, 05:59 PM   #1 (permalink)
Cube012's Avatar
Talking
Anyone ever try using nitrogen in their tiers? I have been hearing a lot about it and have been thinking about doing it.
If anyone is interested check out this website!
http://www.getnitrogen.org/
Cube012 is offline   Reply With Quote
Old 02-04-2007, 06:12 PM   #2 (permalink)
StylinM6s's Avatar
Send a message via AIM to StylinM6s
Can't see it making a significant difference since we breath about 78% of nitrogen.
2005 Mazda 6s V6 MTX Glacier Silver, Black Leather, Loaded, 30% tint
SOLD!
Now: 98' Mustang Cobra SVT
4.6L V8 32v
1 out of 356
My Cardomain
StylinM6s is offline   Reply With Quote
Old 02-04-2007, 08:47 PM   #3 (permalink)
FrozenPilot's Avatar
http://www.getnitrogen.org/why/index.php
This page says it all. Benefits are less pressure loss, no moisture (so no internal corrosion), less rubber oxidation. Pure nitrogen doesnt work since oxygen will permeate back into the tire, ideal Nitrogen/Oxygen mix is 93-98%.
Thats all fine and good, but you pay for it, and topping off with nitrogen is harder to do.
If you read, there really isn't much benefit to nitrogen
Nitrogen fluctuates with temperature change, but it does so less than when water vapor is present.[/b]
So dry air is just as good.
The Federal Aviation Administration requires nitrogen in aircraft tires because it reduces the potential for water vapor freezing at high altitudes.[/b]
Again with the water vapor. Corrosion is also a big issue for aircraft.
In addition, airlines such as Boeing use nitrogen membranes or “OBIGGS” on-board inert gas generation systems (OBIGGS) to layer fuel tanks with inert nitrogen. Again, this reduces the potential for explosions.[/b]
Boeing is NOT an airline. OBIGGS is for fuel tanks, think TWA flight 800. Fuel isn't in your tires, is it?
The way I see it, its more important to eliminate/reduce moisture than use nitrogen. Nitrogen has its uses, but in a street car, they're just trying to sell a product.
'06 6i driver
FrozenPilot is offline   Reply With Quote
Old 02-04-2007, 10:43 PM   #4 (permalink)
robertguio's Avatar
Yeah Bro nitrogen is for pussies!!!
robertguio is offline   Reply With Quote
Old 02-04-2007, 10:44 PM   #5 (permalink)
zxc1104's Avatar
Send a message via AIM to zxc1104 Send a message via MSN to zxc1104 Send a message via Yahoo to zxc1104
i just use plain' ol' regular air...?
zxc1104 is offline   Reply With Quote
Old 02-04-2007, 11:18 PM   #6 (permalink)
mtxpert's Avatar
Nitrogen is awesome for racing tires as it doesn't expand/contract under heat, this is where it's application shines.
2006 300C SRT8 on 22's 13.5@106 N/A (supercharger coming soon!!!)
2003 PSD Excursion 14.2@92
mtxpert is offline   Reply With Quote
Old 02-05-2007, 09:26 AM   #7 (permalink)
Yeah. I did the calculation bit. I'd save approx 178 a year. Whooptie.
Added that there's only one place here that will do it yet. And that's a Costco. They require a membership and a purchase of tires from there to be eligible for their nitrogen service. I think I'd be out the 178 I'd save... hahahaha
Kincaid is offline   Reply With Quote
Old 02-05-2007, 12:55 PM   #8 (permalink)
I was asked if I wanted Nitrogen in my GTO tires when purchased. It was 2 bucks per tire and lifetime refills if needed for those tires so I did it.
Can't say it helped/can't say it hurt anything. I certainly didn't feel anything different but it was nice to know that the weather changes would naot affect the pressure in my tires once set
2006 Mazdaspeed 6
386awhp/376awtq
beat that!
intake Performed by whoosh
whooosh is offline   Reply With Quote
Old 02-05-2007, 01:23 PM   #9 (permalink)
bfischer's Avatar
Nitrogen is awesome for racing tires as it doesn't expand/contract under heat, this is where it's application shines.[/b]
Maybe I am misunderstanding you, but a first year chemistry class will tell you that all gases expand and contract as temperatures change in a closed system.
bfischer is offline   Reply With Quote
Old 02-05-2007, 01:34 PM   #10 (permalink)
mtxpert's Avatar
Nitrogen molecules are bigger than oxygen molecules, so nitrogen seeps out more slowly from tires than air; nitrogen resists heat buildup better than air, which contains moisture; and nitrogen reduces oxidation, which can damage the tire from the inside out, proponents say. Nitrogen is an inert gas, so there are no safety or environmental issues.
According to what I've seen, the tire temperature difference in race compound tires will cause up to a 5 PSI swing in air vs less than 1 PSI in nitrogen.
