Old 12-07-2006, 01:21 AM   #1 (permalink)
stive403's Avatar
Ok, so here's the deal. I ordered a set of alt sonix at-267 18x7.5 rims from victoria tire. Plugged in my car info, 2006 mazdaspeed6 and it came up as being an appropriate fit. I know from researching rims for the past month or so that these rims come in both 35 and 42 offset and that going with a 215 tire on a 7.5 inch rim on a 42 offset, I should be ok without rolling (close though). However, i'm pretty sure with the 35 I would have to roll and the rims might look too far out on the car.
question is, am I wrong to think that they should provide a full refund as they said this rim was an appropriate fitment for my car and we all know that these cars take high offset rims and 35 is definitely not in that category? Just want to make sure when I call them tomorrow that I'm confident in my reasoning.
So pissed, rims and tires show up today, all ready to get them mounted and balanced and on the car, and as I'm looking over the rims I see an "et 35" imprinted on the backside of one of the spokes...
Let me know what you guys think. Thanks
stive403 is offline   Reply With Quote
Old 12-07-2006, 01:26 AM   #2 (permalink)
Hockyguy171's Avatar
Send a message via AIM to Hockyguy171 Send a message via Yahoo to Hockyguy171
So you ordered the 42 and got the 35. Well if thats the case your receipt should say that and you will get your 42's with no hassle. But if the receipt says 35 idk what will happen then.
2006 Velocity Red Mazdaspeed 6 GT
Autoexe CF Front lip | Autoexe CF Grille | Autoexe CF Side Pillars | 18x8 TSW Trakstar 5 | Corksport FMIC custom pc'd | Turbosmart BOV | Corksport Res TP | AE Tower bar | Car-led tail lights | TWM shifter kit w/bushings | TWM Desert Eagle knob | Apexi Full-auto TT | Shark fin | 35% tint | Rear tinted reflectors | Nightshade clear side markers | Xtec Angel Eyes | Apexcone 6000k H1 | PIAA fogs | MSD DH | Prosport Boost/Vaccum Gauge | Audiolink Ipod Connector | COBB SRI | COBB shifter weight | SU rear engine mount | Goodyear Eagle GT | Muteki Lugs
Hockyguy171 is offline   Reply With Quote
Old 12-07-2006, 01:29 AM   #3 (permalink)
stive403's Avatar
that's just it, it doesn't say any specific offset anywhere, online, on the reciept, nothing. I figured since every other website I went to specified high offset rims (42+) that these were the 42 offset variety. unfortunately from the designation on the rim it is not.
Old 12-07-2006, 01:35 AM   #4 (permalink)
JDMAtenza21's Avatar
Send a message via AIM to JDMAtenza21 Send a message via Yahoo to JDMAtenza21
You would need more than a roll to fit 35mm on, might even need to pull the fenders out a little bit. You might need a roll with the 42 too. I had 42mm rims wrapped in 225/45R18 and I needed a roll. You said you would get a 215 tire tho, are those thinner than 225? (I don't really know much about tires).
Anyway onto the rims, if you knew that they came in 35 and 42 then why didn't you specify that you needed the 42 when you ordered them? Or did you? If you did specify you wanted the 42 offset, and they sent you the 35, then they should be held responsible for sending you the wrong rims and should refund your money or send you the 42mm ones.
Why would you order rims without knowing what offset they were? I'm confused
2008 Acura TL Type-S
Nighthawk Black Pearl
The Carbon Volcano SOLD!
DO WORK
JDMAtenza21 is offline   Reply With Quote
Old 12-07-2006, 01:39 AM   #5 (permalink)
stive403's Avatar
that's a little bit of my concern, as I didn't specify 42 when I ordered, at the time of ordering it had slipped my mind that there were two offsets for this rim. And either way, if they say it fits a car, it should fit a car... every other website only recommends high offset rims.
In retrospect I should have verified it was the 42, but I don't think this is fault (at least not the majority of fault at least) and I would like to make sure I can get a free of charge exchange.
a 215 is 10 mm narrower than a 225, so it will effectively be 5 mm narrower at the interface that matters as far as rolling. so a 225 on a 42 offset would stick out as far as a 215 on a 37 offset. So basically if I did put these tires on these rims I would only be 2mm further out than you are.
Old 12-07-2006, 01:41 AM   #6 (permalink)
anotherM6's Avatar
this is why when i ordered my rims, i made it clear and detailed about the sizing from the bolt pattern to the hub bore to the offset.
good luck though!!
2003 steel grey mazda6s mtx appearance package
GARAGE
anotherM6 is offline   Reply With Quote
Old 12-07-2006, 08:57 AM   #7 (permalink)
technically, they do fit. so its not like they are giving you false information about that. if you talk cool to the sales rep, you might be able to just exchange them for a different offset. but be prepared to pay for the shipping. that's my 2 cents.
bluelion is offline   Reply With Quote
Old 12-07-2006, 09:20 AM   #8 (permalink)
stive403's Avatar
yeah, that's kinda what I'm thinking. Still a little pissed at them, but primarily at myself for letting that slip my mind. If it costs me shipping back and no re-stocking fee, I'll be fine with that.
And yeah, it does technically fit my car, but so does a zero offset and you would never be able to tell someone that with a straight face (or if you can, than you need to start selling ice cubes to eskimos).
Old 12-07-2006, 09:54 AM   #9 (permalink)
lilmira's Avatar
How much are they?
lilmira is offline   Reply With Quote
Old 12-07-2006, 10:08 AM   #10 (permalink)
stive403's Avatar
How much are they?
Oh, I'll hook you up with a real solid price! MSRP is 1 cube for $1, but I'll hook you up for the low low price of 10 cubes for $9.99!!! that's right, I know, I"m losing my ass on this deal, but I got your back here. ha.
