Old 11-28-2006, 11:36 AM   #1 (permalink)
oldeguy
Guest
Posts: n/a
Found a set of wheels that they say will fit acording to their spec's. here is the wheel size...comments from the speed6'er?
ADR WHEELS, Style: ADR M SPORT, Bolt Pattern: 5x100 or 5x114.3 , Size: 17"x7" Offset: +48mm
Want to use 215/50/17 tires...any issue with clearances or tire rubbing?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=120054611027
Old 11-28-2006, 12:13 PM   #2 (permalink)
mk706's Avatar
you should have no problems with 215/50/17 with the +48 on stock suspension. several members are running that set up for winter. keep in mind the high load requirement to support the MS6, >/= 93YXL.
2006 MS6-GT Black Cherry Mica
2007 Mazda CX-7 GT-AWD Crystal White Pearl
<strike>2005 M6s-5door Steel Gray</strike>
<strike>2004 M6s-4door Sepang Green</strike>
Semper Fidelis
mk706 is offline   Reply With Quote
Old 11-28-2006, 02:29 PM   #3 (permalink)
oldeguy
Guest
Posts: n/a
OK...thanks mk706 for the feedback. What is the high load requirement 93YXL?
