I have a set of rims for my 6 a friend of mine has liying around (snows on steels). The lugs partern is correct. The only issue is the center hub on the car is slightly smaller by an 1/8th of an inch. I'm thinking that the center hub carrys some of the load, but not really sure if my assumption is correct. My question is can I still use the rims?
Your Dream girl sitting at the end of the bar is another man's nightmare. |
Several companies make hub centric rings that will help in this area. You need to know the diameter of the rim you are placing on your car, measured in millimeters.
The Mazda6 hub is 67mm. You'll be looking for an adapter (hub centric ring) that will accomodate your new wheel. I purchased mine online at discounttiredirect.com. They are made of aluminun and cost slightly more than other companies that make them out of plastic (or similiar).
#3 (permalink) | |
Thanks.. If they are plastic that means it doesn;t really carry any load?
#4 (permalink) | |
That's why the add-on rings are called "hub-centric rings". They make the wheel "centered" on the hub. This of course, is different from true racing wheels, which do use only one large nut, so the bores on those wheels have to match the hub.
2006 MazdaSpeed6 Sport in Liquid Platinum Metallic Beautiful BC, Canada Changes: 3.25" ETS TMIC, Forge BPV, SU Boost Tubes, RPM Prototype Sport Springs, TWM Short Shifter and bushings, SU motor mount, Nokya H11 yellow foglights, RX8 wheels on 235/40 General Exclaim UHP, rolled fender lips, Fujita CAI, 3" custom single outlet exh with 2 (yes, 2) Magnaflow resonators, SpiralFlow and Aeroturbine muffler, Osram Silverstar H1 high beams, Turn signal mod, MazdaSpeed6 badge removed Planned: VEI boost gauge (have) + Top PSI vent pod (ordered), CPE Standback EMS ![]()
#5 (permalink) | |
Keith_MS6
Keith_MS6 2006 Speed6 GT, Liq Plat. Wheels: Kosei K1 TS, 17x7 w/ 50mm offset. Tires: Yokohama AVID V4S, 225/50-17. Michigan |
