Old 04-27-2006, 05:10 PM   #1 (permalink)
ryceboi's Avatar
ok, i got some new wheels. ALT rival +42mm offset 18x7.5 w/ the stock Potenza RE050A 215 tires. the center bore is 73mm so i got some hub centric rings (67.2mm to 73mm) and mutegi tuner lugs. im getting quite a bit of vibration in the steering wheel at speeds of 60+mph. nothing violent, but its enough that it gets annoying. All the tires were balanced during mounting and im assuming they're facing the right direction since the "OUTSIDE" mark on the tires is facing outside. these are Y-rated tires btw so i don't believe they are directional. does anyone have a clue to why im getting the vibration?
ryceboi is offline   Reply With Quote
Old 04-27-2006, 05:20 PM   #2 (permalink)
Administrator
Mazda Gremlyn's Avatar
Vibration at speed would lead me to believe its a balance issue. Take the car back to the shop that installed them and have them double check the balance.
Just because it says "outside" on the tyre, doesn't mean it is facing the right way, you can double check that the tread it going the right direction, but I don't see that giving you much vibration even if they are wrong.
2004 Mazda6s MTX: Injen/CP-E Tunable, Espelier Lowering Springs, Racing Beat Sway Bars, 6gunrocket endlinks
1988 323 GTX: It LIVES!!
Mazda Gremlyn is offline   Reply With Quote
Old 04-27-2006, 05:23 PM   #3 (permalink)
ryceboi's Avatar
i dont remember which direction the tires were originally facing. ill post in the mazdaspeed section for verification. ill probably take it back to the shop later after i get some info here. thanks gremlyn.
Old 04-27-2006, 05:29 PM   #4 (permalink)
Administrator
If they are monodirectional, the tread lines would be in a v-like shape pointing towards the ground and in the direction they are moving. Basically, look at the tyre from the front of the car, and you should see the lines going like this: \ /
Old 04-27-2006, 05:32 PM   #5 (permalink)
ryceboi's Avatar
http://www.tirerack.com/tires/tires.jsp?ti...re1=yes&place=0
this is the tire. the drivers side is facing opposite the passenger side currently.
edit:
ive only seen the V's on z-rated tires and usually they have a rotation arrow on the outside of the tire.
Old 04-27-2006, 06:07 PM   #6 (permalink)
crossbow's Avatar
Directional tires usually have an arrow on the sidewall to tell you which direction they should be facing. These tires appear to not have any particular directional arrows. However one would assume it would be better for the arrow shapes on the tread to be pointing towards the front of the car, instead of the rear.
Other then that, I agree with mr Colin of the Balance Issue.
crossbow is offline   Reply With Quote
Old 04-27-2006, 06:10 PM   #7 (permalink)
ryceboi's Avatar
k, im heading to the tire shop as soon as i finish posting my catch can install. thanks guys.
Old 04-27-2006, 07:38 PM   #8 (permalink)
ryceboi's Avatar
tires are balanced just fine. i cant think of anything else. perhaps warped rotors? but the car is only 4 months old. ill probably have to take it to mazda for them to check.
Old 04-27-2006, 07:53 PM   #9 (permalink)
Slv6sPitt's Avatar
Do any of the tires have bulges in the sidewall?
Also, from what I understand, hub centric rings "assist" in getting the wheel aligned properly on the car, but the lug nuts really do the final alignment. Is it possible that one of the wheels is not 100% aligned?
2005 Mazda 6s Sedan - MTX, Bose, Leather
Slv6sPitt is offline   Reply With Quote
Old 04-27-2006, 07:53 PM   #10 (permalink)
Marko343's Avatar
Send a message via AIM to Marko343 Send a message via MSN to Marko343 Send a message via Yahoo to Marko343
Take it to another shop.
Not all shops balance them well, My shop I work at has ppl come ALL the time to rebalance fromt Pep Boys or other tire places, have them put them on the balancer before the take the weights off and see if it was off.
Most shops stay content with it being .25oz off and leave it, make sure it was balanced to 0, .25 oz shouldn't cause it but wheels vary.
~-~-~-~-~-~-~-~- ^CarDomain Link^ -~-~-~-~-~-~-~-~-
Marko343 is offline   Reply With Quote
