Old 10-23-2005, 09:45 PM   #1 (permalink)
backman_66's Avatar
Send a message via AIM to backman_66 Send a message via MSN to backman_66
I'm looking at buying 17x8 +45 offset rims wrapped in 235/40/17 T1-R's
I'm running on Tanabe GF springs with the v6. Soo, just wondering if these will be a problem with rubbing after fenders are rolled? Would I have to roll them all the way you think?
The new setup will stick out 1" farther...
backman_66 is offline   Reply With Quote
Old 10-23-2005, 10:02 PM   #2 (permalink)
+45 offset rims you'll be fine if you have the fender rolled
since you have 17", now the key'd be the tire you choose
i'm not sure about 235 but itz always good to step off a bit
don't worry...the little inch would make a big differnce
king_lam925 is offline   Reply With Quote
Old 10-23-2005, 10:04 PM   #3 (permalink)
backman_66's Avatar
Yeah, because I know 17x8 w/ 245s fit with fender rolled.. on +48 offset SSR Comps
Just wondering if the 3 less offset would make much of a difference
Old 10-23-2005, 10:17 PM   #4 (permalink)
3 less offset would make a difference
some people are using 42 but they're still fine with the fenders rolled but sometime they'd find there's rubbin if there're 2 or more people sitting at the back or too many stuffz in the trunk or going too fast towards a bump
to be secured, i'd suggest +45 offset becuz 45 is the safe level i think
