Old 10-23-2005, 06:05 PM   #1 (permalink)
I tried searching but I really couldn't find my answer specifically. i am going to get a 19 x 7.5 with 53 offset rims. And i was wondering if 235/35/19 will fit the rim width? or will i have to go with teh 225/35/19? is anyone running a 7.5 width rim, and a 235/35 size tire?
yankees7 is offline   Reply With Quote
Old 10-23-2005, 06:56 PM   #2 (permalink)
HighSpeed6's Avatar
Send a message via AIM to HighSpeed6
Originally posted by yankees7@Oct 23 2005, 05:05 PM
I tried searching but I really couldn't find my answer specifically.* i am going to get a 19 x 7.5 with 53 offset rims.* And i was wondering if 235/35/19 will fit the rim width? or will i have to go with teh 225/35/19? is anyone running a* 7.5 width rim, and a 235/35 size tire?
[snapback]540881[/snapback]
i am looking at a similar same setup, and i wasn't sure if i should go with the 8 inch wide rim, so i can use 235/35 or if i should just play it safe and go with the 7.5 inch wide rim and go with 225/35. does anyone know if 8 inch wide, and 235/35 (53 offset) will work?
HighSpeed6 is offline   Reply With Quote
Old 10-23-2005, 07:52 PM   #3 (permalink)
Jax6S's Avatar
From the sticky:
225/40R19 7.5"-9.0" 34 psi
235/35R19 8.0"-9.5" 39 psi
245/35R19 8.0"-9.5" 36 psi
So, if you want to use 7.5", I think you should use 225/40R19. Otherwise, go buy the 8" so you can use 235/35R19.
2006 Black Mazdaspeed6
Jax6S is offline   Reply With Quote
Old 10-23-2005, 07:57 PM   #4 (permalink)
HighSpeed6's Avatar
Originally posted by Jax6S@Oct 23 2005, 06:52 PM
From the sticky:
So, if you want to use 7.5", I think you should use 225/40R19.* Otherwise, go buy the 8" so you can use 235/35R19.
[snapback]540951[/snapback]
do you think the 8" and 235/35 will work without rubbing (fenders rolled) (53 offset)
Old 10-23-2005, 08:24 PM   #5 (permalink)
Jax6S's Avatar
[snapback]540956[/snapback]
I have no idea. However, check out this thread. Maybe it will give you some more info regarding this.
