Any problems will occur if i do that?
Like, 17" w/ 215/40/17 for fronts and 18" w/ 225/35/18 ? OR 18" w/ 225/40/18 for fronts and 19" w/ 235/35/19 ? Cz my mom's bmw 330i's setup is like that, and i like how it flows... But not the US-/Canadian-spec BMW though... it's from my country...
Tanabe GF210 Springs, AutoExe CF grill, Retrofit (Bosch E46/Audi TT DOT projector) + Philips D2S 5000K (85122+) bulbs, Lower fog, 2 x 10" Sony Xplod, MTX MXA6001 Class D amp, 12" Varad White LED bar + 4 x Varad single LEDs, Airbox Mod, Sidemarkers Mod, Taillight Mod, Foglight Mod, Clear sidemarkers, 4 x white 6-WLEDs, 4 x white 5-LEDs, 2 x orange 5-LEDs, 2 x Polarg Hybrid XenonWhite 194 bulbs, 2 x blue 921 LEDs, 2 x OEM muffler tips,Redline MTX fluid, Ichiban Shift Knob, Ractive Shift Boot, TWM short shifter, Focal PolyGlass 130v1 components, Infinity 6802cf, Duplicolor Red caliper paint, Royal Purple 5W20 Synthetic Oil, Hawks brake pads |
I don't think so. But yours moms BMW is also rear wheel drive which is why its staggered.
64 mods (so far) Too much money spent ![]() http://forum.mazda6club.com/index.php?&...E=12&CID=17 6 of the month on eastcoast6.com March 2005 NH01 http://www.cardomain.com/memberpage/859418 (better pics) and check out myspace http://www.myspace.com/21633211 |
Regional Moderator
Provided the wheels are the same size on the same axle you should be fine. Keep the fronts the same Keep the rears the same. If the tires are all 225 or 215 width you handling should stay near the same, provided the wheels are not a 10 lb difference.
I think Blazn is using a staggered stepup.
CANADA / TORONTO MAZDA6CLUB MODERATOR Current Dyno - 205whp, 180wtq |
Yeah, but Blaezn is using his mainly for a show car.
#5 (permalink) | ||
Btw, your 17/18 tire sizes are way too small. If you go that route, you will need 225/45R17 F and 225/40R18 R or 235/40R18 if you want wider in the rear.
You would want a wider wheel and tire up FRONT, not in the rear. I run a staggered setup with the wider tires up front and it drives great.
Of course, since all the weight is up there, that's where you'd want to ensure you have a tire with a high load rating, too. As ToyoGuy said, you wouldn't want to put a rubber band there for a tire. You could conceivably use 245/40/17 up front on a 17x8 and 225/40/18 rear on a 18x7 to get the look you want and still have good performance, but I think it'd be pretty silly to do so. The front tires do everything on a front wheel drive car- optimize them as much as possible.
Understand suspensions? Please take the required measurements for my suspension calculator and share them on this site. |
#7 (permalink) |
Hmm yeah,, i forgot that BMW is RWD.....
doesnt it look weird if i get wider tires for fronts? and i hardly see any wheels that have 17x8
#8 (permalink) | |
but for the track, it does help depending on how you want your car to handle and also on how your suspension is already setup... stretch uses wider tires up front for autox.... and some race tuners as well for the track.. again, depending on how they want the car to handle... |
#9 (permalink) |
i m not going to autox my car.... hehe
so what if i get same width for fronts and rears, but for the fronts, i get 40 and rear i get 35 ? (for 17"F/18"R)
#10 (permalink) | |
but its your car though... go with toyo's advice above (225/45R17 F and 225/40R18 R) if you still want to do it with the same width. |
