Old 01-21-2005, 03:11 PM   #1 (permalink)
Comm MD's Avatar
Heres the deal. I purchased some aftermarket rims as you can see. When I put them on and drove on them, I have a nice vibration going over 40 mph. Going off that and purchasing these rims balanced, I ordered some hubcentric rings. Putting those on yesterday had no effect whatsoever. Now heres a kicker, sometimes(like once every 2 days) the vibration goes away for like 15 seconds and then comes back(extremely wierd). Before I had these rims, I had no vibration whatsoever, even goin 115MPH so I'm rulling out any steering/suspension probelms. So I'm stuck between a rock and a hard place. Do you think they were balanced wrong? Or has anyone else had this problem before. I looked on each rim and there are weights on all of them(in case they missed one). All the tires look normal too. I NEED HELP! Any suggestions??????
Upgrades: K&N SRI, Racing Beat exhaust, Eibachs, Diablo Lionhart 18" w/Falken Ziex ZR-512, Kicker L7, Memphis SD-500 w/Cap, Full tint, Beltronics RX67 Pro Radar Det, EBC Brakes.
Upcoming: Stage 2 clutch, NGK Plugs, and more.
Comm MD is offline   Reply With Quote
Old 01-21-2005, 03:20 PM   #2 (permalink)
Regional Moderator
Mazda6sMtx's Avatar
Are the wheels torqued properly ??? 85 ft-lbs i think is what our wheels should be at. Please correct me if i'm worng.
Mazda6sMtx is offline   Reply With Quote
Old 01-21-2005, 03:27 PM   #3 (permalink)
Comm MD's Avatar
[snapback]351583[/snapback]
Yup
Old 01-21-2005, 04:31 PM   #4 (permalink)
How long did you drive without the hubcentric rings? It's possible that the vibration warped the wheel a bit if you drove too long.
But, first off, I'd get them balanced again. I don't trust when you buy them pre-balanced. I've done that twice, and both times they weren't balanced worth a damn. It shouldn't cost you more than about $40.
Revolution Performance Motorsports
Sigma is offline   Reply With Quote
Old 01-21-2005, 04:56 PM   #5 (permalink)
Comm MD's Avatar
Yeah I figured thats probably the reason, at least I hope it is. I'll get them rebalanced on Sunday. But if there is any more suggestions let me know.
Old 01-21-2005, 05:11 PM   #6 (permalink)
Tire Guy's Avatar
Balancing is the likely culprit, but sometimes tires can slip a little on chrome plated wheels. It's possible the tires were balanced correctly and then after you drove on them a bit, the tires have moved from their original mounting position (due to acceleration and braking torque forces).
Take them to a tire shop and have them check each one first before rebalancing.
My Current Car
My Previous Car Page
_______________
<div class='quotetop'>QUOTE
Old 01-21-2005, 09:00 PM   #7 (permalink)
leftyrev's Avatar
i had a very similar problem with my last car , i never got to figure out what it was , i just ended up blaming it on the rims since i got them pretty cheap , it was wierd one day it would be fine next it would shake alot , upto 40mph no problem , over that started shaking until i reached about 60 mph, i just got used to it hope this is not the case for you
leftyrev is offline   Reply With Quote
Old 01-21-2005, 09:20 PM   #8 (permalink)
Comm MD's Avatar
[snapback]351742[/snapback]
I HOPE NOT. Thanks for your input
Old 01-21-2005, 09:43 PM   #9 (permalink)
Bulybuoy's Avatar
Leftyrev , i had the same issue as yours , one of my precious cars was a 2000 corolla , put on it some 16" , the thing is , they did the same , vibrate from like 90 or 100 km , till 120 or 130 km , i balanced them like 5 times in diff. shops! got the centric rings , did everything , went from 215/40/16 to 205/45/16 , and still that vibration , then i just couldn;t find any other thing to blame but the rims themselves , since i got them really cheap , and realized they were an exact copy of the Konig Flight. so guess the rims were so bad quality , nothing could be done!
i just say , don;t get any wheels , get some branded recognized ones , that;s all , with the right specifications , and u should be alright!!
[COLOR=blue][SIZE=1][FONT=Optima][B]
JDM Mazda 6i Black Mica 2005
Santo Domingo , Dominican Republic
Bulybuoy is offline   Reply With Quote
Old 01-23-2005, 01:49 PM   #10 (permalink)
Comm MD's Avatar
[snapback]351645[/snapback]
Well come to find out, you were right. The balancing was way off(like 3.5oz) on each tire. Total idiots dont know what there doing. So A note for everyone. Double check or visually watch your wheels getting balanced. Also ensure they do both types of balancing(static and dynamic). I guess the first place only did static balancing. Hope this helps others if you had the same problem.
