Old 06-28-2004, 04:26 PM   #1 (permalink)
b0b
Default rotating tires
can you rotate your tires yourself? how would i do it with tires with directional threads? thanks.
b0b is offline   Reply With Quote
Old 06-28-2004, 04:38 PM   #2 (permalink)
GreenNuggs's Avatar
Default Replying to Topic 'rotating tires'
Of course! Why pay someone to remove lug nuts for you? If they truly are unidirectional, just switch the front left/back left and then the front right/back right.
If not, bring the rears to the front on the same side, and switch the ones that were in the front to the opposite side in the back (its in the manual)
2003 Mazda 6s - MTX, 1SE, Moonroof, SAB - Nuggs' 6
Draxas Exhaust, Injen Intake, Eibach Springs, CP-E MAF customizer, Rota Torque 17x8, 235/40ZR17 94Y, 14.933@94.9
"Thats what the internet is for! Slandering others anonymously!"
GreenNuggs is offline   Reply With Quote
Old 06-28-2004, 04:40 PM   #3 (permalink)
timba24's Avatar
Send a message via AIM to timba24 Send a message via MSN to timba24
Default Reading Topic: rotating tires
um I thought the manual just said to do front to back im pretty sure thats what it says I dont remember anything about switching sides
timba24 is offline   Reply With Quote
Old 06-28-2004, 04:46 PM   #4 (permalink)
1hot6's Avatar
i do front to back, cause it makes perfect sense...but i also think that you can flip flop them as well.
2004 Mazda6s 5 Speed Manual Lapis Blue Metallic
Current Modifications:
Injen CAI, Magnaflow Catback Custom NO Resonator, 8000K HID Kit from Xenondepot, 20% tint, Brakelight Mod, Grounded TB
1hot6 is offline   Reply With Quote
Old 06-28-2004, 04:59 PM   #5 (permalink)
DAGMZ6S's Avatar
Almost positive that the manual says that the backs go straight up and the fronts go to opposite side in the back. You can do this by jacking up the car in the front with jack stands on both sides and using the rear center jack point to lift the entire back.
2006 Titanium Grey Mazdaspeed 6 - now only mostly stock...
DAGMZ6S is offline   Reply With Quote
Old 06-28-2004, 06:58 PM   #6 (permalink)
b0b
Originally posted by DAGMZ6S
* * * * * * Almost positive that the manual says that the backs go straight up and the fronts go to opposite side in the back. *You can do this by jacking up the car in the front with jack stands on both sides and using the rear center jack point to lift the entire back. *
but then the direction of the tread on the 2 rear tires will be going to wrong way...
Old 06-28-2004, 07:30 PM   #7 (permalink)
timba24's Avatar
correct thats why its just front to back
Old 06-28-2004, 11:12 PM   #8 (permalink)
1hot6's Avatar
its the only thing that makes sense to me
Old 06-29-2004, 10:28 AM   #9 (permalink)
GreenNuggs's Avatar
The STOCK Michelins are NOT DIRECTIONAL.
If the switch isn't in the manual than I will eat crow. But I'm pretty sure it is. If its not, its because I'm thinking about my previous car. But bOb says his tires are directional so he should just do front to back.
Old 06-29-2004, 11:50 AM   #10 (permalink)
b0b
Originally posted by GreenNuggs
* * * * * * The STOCK Michelins are NOT DIRECTIONAL.
If the switch isn't in the manual than I will eat crow. But I'm pretty sure it is. *If its not, its because I'm thinking about my previous car. *But bOb says his tires are directional so he should just do front to back.
thanks.
