Administrator
DISCLAIMER: Just because one member did not experience rubbing with a specific wheel/tire combo, that doesn't mean that you won't either. Individual results may vary based on the type of driving you do and your suspension setup. ************************************************** ********** OK, so the idea here is for everyone that has changed their wheels or tires, etc to post up what they have, include pictures if you like. This way if anyone has questions about what will fit and what won't, they can see what everyone else has done and get ideas. This is not a thread for discussion, so please post only if you are putting up information. Any posts not strictly on topic for this thread will be deleted. Questions about a member's setup should go through PM to that member. Also please note that if you do not post information with the wheel, the post will be deleted. Include the name/brand, size, and offset. If you're not sure about one of the specs for the wheel, you can try looking at http://www.wheelspecs.com I'll start with an example using the stock wheel setups: (info taken from Doc Roadster) OEM 16in wheels Tires: 205/60/16 - North America 205/55/16 - Everywhere but North America Wheels: Mazda OEM 16x7 +55mm offset Weight: 21.1lbs OEM 17in wheels Tires: 215/50/17 - North America 215/45/17 - Everywhere but North America Wheels: Mazda OEM 17x7 +60mm offset Weight: 21.1lbs |
| The Following User Says Thank You to Mazda Gremlyn For This Useful Post: | chicksamazing (01-26-2013) |
| Sponsored Links | |||
Advertisement | |||
RH C5 Evo
Wheels: 18x7.5 +42mm offset Tires: Dunlop W10 215/40/18 springs: eibach pro kit fedner: did not rub at all with eibach, so did not roll the fender
GramLights 57pros
Wheels: 18x7.5 +52 offset - fit fine w/ no rubbing Tires: 225/40-18 Toyo T1-R About 43lbs per corner. I think the rims are about 19.5 lbs each Eibachs Lowering Springs I drove pretty hard with them on too. Next time I'll try 225's. I'll post pics when I get my cam back. [Here is a picture until you get the ones of your car - MG]
64 mods (so far) Too much money spent ![]() http://forum.mazda6club.com/index.php?&...E=12&CID=17 6 of the month on eastcoast6.com March 2005 NH01 http://www.cardomain.com/memberpage/859418 (better pics) and check out myspace http://www.myspace.com/21633211 |
| The Following User Says Thank You to DRAGONS6 For This Useful Post: | tylerbriggs (02-06-2012) |
Wheels: Volk GT-U 18 x 7.5 +50 offset
Tires: Pirelli P-Zero Nero 225/40/18 Springs: H&R Sport No rubbing, no fender roll. ![]() ![]()
Groans: 7
Stock RX-8 wheels
18x8 Tires: 225/45/18 Sprint Lowering Springs ![]()
Pull me over Red 2006 mazdaspeed6 GT, moonroof, 6061 Forged 19x7.5 gunmetal wheels (14.5lbs ea.), Megan 2" drop springs, SU motor mount. |
| The Following User Says Thank You to 6DereK6 For This Useful Post: | sams302 (06-24-2011) |
Konig Imagine
Black Opal Finish 19 x 8 +45 Nitto Extreme 225/35 No Drop No Rubbing
#7 (permalink) |
ASA AR1
Wheels: 18x8 +35mm offset Tires: Dunlop SP 9000 225/40/18 springs: eibach pro kit fender: had to be rolled as far as possible, rear wheel wells had to be slightly pulled. No rubbing. ![]()
I want to die in my sleep just like my grandfather did and not screaming and yelling like his front seat passenger. |
#8 (permalink) |
Motegi MR7
Wheels: 18x7.5 +45mm offset Tires: Kuhmo 225/40/18 springs: Stock fender: Have not rolled, and only rubbed once with people in back and going into a steep driveway
2003 Mazda 6s ATX - Current Mods - Erebuni Front Lip, Silviaparts Grill, Custom APC Mesh Grill Inserts, 18" Motegi MR7 Chrome Wheels, Clear tail lights, OBX Racing Exhaust, Injen Intake, CPE MAF Customizer, Redline D-4 Synthetic ATF, 2 12" Polk Audio DX Subs w/ Rockford Amp, Sylvania Silverstar H1's, Blue LED interior lighting *Coming Soon* - Lotek Center Mount Gauge Pod w/ Autometer Ultralight Gauges, Racing Beat Springs / Sways Package |
#9 (permalink) |
Wheels:
SSR GT7s 18x8 +48 offset Tires: Toyo Proxe4 225/40/18 Springs: Stock Fenders: Rolled
#10 (permalink) |
Here is mine. 18x7.5 Maxxim Eracer wheels +45 offset with 215/40/18 Yokohama Parada Spec 2 tires. Max grip tires.
![]() ![]() ![]() ![]() ![]() This is with a Eibach drop and no fenders rolled. No problems with rubbing.
Black CP-E CAI/Black HKS BOV/TurboXS RP/RX-8 Wheels/MS6 Coming soon... LOL |
Advertisement | |
