Old 02-05-2004, 04:24 PM   #1 (permalink)
84FordMan's Avatar
Default Drag Radial Setup
Putting together what I will want to put on my car for the drag strip and just want some outside opinion now.
The tires will be Nitto 555R Drag Radials, as the BF Goodrich alternative does not have any tire size close to us using.
245/50R16
245/45VR17
Wheels is a good sized list, looks really don't matter much here, since performance is the goal.
Racing Hart CP-035
Racing Hart CP-035R
SSR Type-C
Volk CE28N
Volk SE37K
OZ Superleggera
Polls never seem to want to work for me... Here are the wheels
Racing Hart CP-035R 17x8 13.6 lbs
Volk CE28N 17x8 38-offset
Volk CE28N 17x8.5 30-offset
Volk SE37K 17x8 38-offset
Volk SE37K 17x8.5 30-offset
SSR Type-C (Competitions) 17x8 14.3 lbs 35-offset
Racing Hart CP-035R 17x8.5 14.4 lbs
SSR Type-C (Competitions) 17x8.5 15.3 lbs 30-offset
OZ Superleggera 17x8 15.9 lbs
Racing Hart CP-035 16x8 11.5 lbs
SSR Type-C 16x8 12.1 lbs 35-offset
Volk SE37K 16x8 38-offset sub-15 lbs
1994 Mazda B3000 SE
Daily driver
84FordMan is offline   Reply With Quote
Old 02-05-2004, 08:20 PM   #2 (permalink)
LapisM6i's Avatar
Default Replying to Topic 'Drag Radial Setup'
you must be a rich man.
LapisM6i is offline   Reply With Quote
Old 02-05-2004, 08:44 PM   #3 (permalink)
Stretch's Avatar
I'd go with 16's with a +38 offset. I figure +40 is the minimum safe offset to run that wide of a tire, and I'd try to stay as close to that minimum as possible. Get whatever's cheapest, IMO- tire weight matters a lot more than wheel weight for acceleration. You'll lower your rotational inertia more by staying with 16's than you would by getting even slightly lighter 17's. Plus, it'll allow the sidewall more room to deform on the launch.
Stretch is offline   Reply With Quote
Old 02-06-2004, 10:35 AM   #4 (permalink)
I agree with stretch. You might even want to look at some Koseis. They are cheap and light... youre at the drag strip so you dont have to worry about hitting potholes...
also skinnier tires in the back and raised pressure would help your launches...
Eric Wong
tireswap is offline   Reply With Quote
Old 02-06-2004, 05:43 PM   #5 (permalink)
Administrator
Mazda Gremlyn's Avatar
Default Reading Topic: Drag Radial Setup
Good luck trying to run some of those smaller offsets! You have to keep in mind the 6 has an unusually high offset. I agree with stretch that 40 is the lowest you should go, but I'd probably stop myself at 45 just to be on the safe side (depending upon wheel width of course).
2004 Mazda6s MTX: Injen/CP-E Tunable, Espelier Lowering Springs, Racing Beat Sway Bars, 6gunrocket endlinks
1988 323 GTX: It LIVES!!
Mazda Gremlyn is offline   Reply With Quote
Old 02-06-2004, 09:26 PM   #6 (permalink)
84FordMan's Avatar
Well I have been using an offset calculator to gauge what is best to use, the stock 17 sits the closest to the inside wheel well, so using that as the starting point an 8" wide wheel with a +38 offset will have 9mm clearance from the rear wheel lip to the suspension and the outer lip will extend 35mm more than the stock 17", which converts to just about 1.5". Doesn't KUNING-6 have 19s with a 36-38 offset?
Eric, what size tires would you recommend for the rear then?
1994 Mazda B3000 SE
Daily driver
Old 02-06-2004, 10:06 PM   #7 (permalink)
Stretch's Avatar
Let's be clear on this, you have no chance of getting those wheels to fit for street use. You wouldn't be able to turn or go over good bumps. However, drag racing is in a straight line, and for that they'd be fine.
245's on a +30 offset would push the tire out 45mm more than stock, about two full inches. You simply can't tuck that much under there.
I was only quoting the minimum offset needed to clear the inside suspension knuckle that extends to the upper A-arm in the front. Check the pictures here:
http://www.mazda6tech.com/cms/index.php?id=90
Old 02-07-2004, 08:27 AM   #8 (permalink)
IceQueenX's Avatar
Originally posted by LapisM6i
* * * * * * you must be a rich man. *
LOL, maybe don't have to be rich but with that money one could probably fly to Canada , climb the Rockies or vacation in Hawaii..hey, we all have priorities. You do or go where you love.
IceQueenX is offline   Reply With Quote
Old 02-07-2004, 02:36 PM   #9 (permalink)
84FordMan's Avatar
Hey Icey, what kind of 6 do you have? Have any pictures of it? I can't seem to find any.
1994 Mazda B3000 SE
Daily driver
Old 02-08-2004, 05:44 PM   #10 (permalink)
IIRC, there's a BFGoodrich g-Force DR that's a really low diameter. If they stick, they will give you a tremendous jump out of the hole with the already short first gear. :)
dawgdan is offline   Reply With Quote
