Old 12-08-2003, 08:00 PM   #1 (permalink)
Default Pad & disk brake specification
Usefull information for all:
Front disk minimum thickness: 23.0 mm.
Maximum variation 0.015 mm from larger minus smallest measures.
Front pad minimum thickness: 2.0 mm
Rear disk minimum thickness: 8.0 mm.
Rear pad minimum thickness: 2.0 mm
* all values are from Mazda6 Workship Manual.
MazdaForLife is offline   Reply With Quote
Old 12-08-2003, 11:40 PM   #2 (permalink)
Default Replying to Topic 'Pad & disk brake specification'
This is below spec.
http://www.jeepaholics.com/citizensband/fo...?TOPIC_ID=23673
LBJay is offline   Reply With Quote
Old 12-08-2003, 11:45 PM   #3 (permalink)
Administrator
Default Reading Topic: Pad & disk brake specification
Holy crap! It took me a second to realize those are the vents for the vented discs and no top disc!!
My Car
Indy MPS6 is offline   Reply With Quote
