Old 10-03-2003, 08:19 PM   #1 (permalink)
Aphextwin's Avatar
Default Need Advice from fellow members.......
Hey everyone...........I'm new to the boards/site, and my 6 has turned one week old today. Lots of information to soak in here........doing a little each day.
I could use some advice/comments/suggestions.......on new wheels.
I want to put 17" (17x7) wheels on my 6 with an offset of 45, and a tire size of 215/50/17, or 215/45/17......the deciding factor will be whether or not the setup will rub anywhere.
Without having to modify any part of the car.......what is the best scenario for a hassle free experience.
I have read the offset on the stock 17's is crazy at 60mm, so this kind of thing is new to me.......meaning, I have never run accross a car that is so picky with it's shoes.
I have also read about fender rolling, and while I do intend on avoinding having to do that..........what in the world is it?
I appreciate any comments anyone has.
Thank You,
Mark
KCK
Aphextwin is offline   Reply With Quote
Old 10-04-2003, 01:10 AM   #2 (permalink)
Default Reading Topic: Need Advice from fellow members.......
i dont think 215 would rub with either 45/50
but 50 sounds very comfortable ride inded :)
KUNING-6 is offline   Reply With Quote
Old 10-04-2003, 01:39 AM   #3 (permalink)
Administrator
I believe a few members have gone to 45 offset with no problems. If I were you, I'd read up around in this topic area to get the information.
My Car
Indy MPS6 is offline   Reply With Quote
Old 10-04-2003, 07:15 AM   #4 (permalink)
OddsNEnds's Avatar
My rims are 17x7 with a 48mm offset and 215/50/17 tires. Not lowering vehicle, so the 50 series tires works out great for me, no rubbing. With 45mm offset you shouldn't have problems.
If you think you want to lower your 6, then the 45 series tires would be the way to go.
OddsNEnds is offline   Reply With Quote
Old 10-04-2003, 09:24 AM   #5 (permalink)
agree with OddsNEnds
the 6 got a deep wheelwell so it shouldn't have any problem with big profile tyres
the rubbing occurs mainly to the outside wall of the tyre when getting wheels with bigger offsets
Old 10-04-2003, 03:27 PM   #6 (permalink)
Default Replying to Topic 'Need Advice from fellow members.......'
QUOTE
Originally posted by KUNING-6
* * * * * * agree with OddsNEnds
the rubbing occurs mainly to the outside wall of the tyre when getting wheels with bigger offsets[/b]
you mean wheels with smaller offsets! i.e. a lower offset of +40 is more likely to rub than a bigger offset of +48.
I have aftermarket 17x7's with a +45 offset and 215/50/17 tires. I have had people in the car and it doesn't rub. However if you drop it more than an inch, I would recommend a 215/45 series tire. I plan on lowering it less than an inch(racing beat springs), so hopefully I won't have to roll my fenders.
npwhite6s is offline   Reply With Quote
Old 10-04-2003, 03:35 PM   #7 (permalink)
QUOTE
Without having to modify any part of the car.......what is the best scenario for a hassle free experience. *
Thank You,
Mark *
KCK[/b]
Hey Mark, I have 17x7s with a 42mm offset with 215/45/17s tires on my 6 (no lowering) and have no rubbing problems at all. You should be just fine with either tire and wheel set up that you mention.:thumbup
steelieman is offline   Reply With Quote
Old 10-04-2003, 09:17 PM   #8 (permalink)
woopsy...my mistake there..ya..i mean smaller offset
doh!brain is getting too much nicotine :(
