Old 09-25-2003, 07:47 PM   #1 (permalink)
Default Offset 45 maximum??
I was going to get a wheel set with 18x7.5 5x114.3 offset 42
but i found out that I can't put it on my mazda 6
What I saw is I can only put offset 45 or higher...
Is it true?
axdave is offline   Reply With Quote
Old 09-25-2003, 08:03 PM   #2 (permalink)
Default Reading Topic: Offset 45 maximum??
did u do fender rolling?
KUNING-6 is offline   Reply With Quote
Old 09-25-2003, 08:12 PM   #3 (permalink)
Stretch's Avatar
Depends on the tire width you want... you could put some nice 195mm wide tires on those rims :-)
I'd be nervous about anything less than 50mm, honestly. The stock 17's have a whopping 60mm offset!
Stretch is offline   Reply With Quote
Old 09-25-2003, 08:46 PM   #4 (permalink)
Default Replying to Topic 'Offset 45 maximum??'
can't put 195 mm tire on
road condition here in boston is bad
easy to get flat if use that thin
at least 215 i think
Old 09-26-2003, 10:37 AM   #5 (permalink)
SCORPION6's Avatar
Location: ACTUALLY IN USA. MIAMI FLORIDA UNTIL December 3, 2009. Panamá (Central America).
I have the 17x7.5 with 225/45 ET=48+. No Problem.
And there are more space to fit. I think the ET=45mm will be ok with my measures
But the 18 will be so close to the fenders and with ET=42mm more to worry. With the 18 you will need as leat a 40 and no dropping car as least you roll the fenders
Mazda 6 (2.0) Automatic. Strato Blue
Rx8 Rims 16x7,5 Offset:+50mm with Toyo Proxes 4 225/50 96V (40,2 lbs).
2.3 Draxas Header. 2.3 AEM SRI. Mobil 1 10W-30. Eibach Pro Kit. Bosch DOT4 Brake Oil. Kashima Brake Pads
Britax Boulevard Baby Car seat. Pulstar Pulse Plugs
SCORPION6 is offline   Reply With Quote
Old 09-26-2003, 10:40 AM   #6 (permalink)
SCORPION6's Avatar
195 on a 18 x 7.5 ?
Old 09-26-2003, 12:37 PM   #7 (permalink)
215/35 or 225/40 is my choice if I put on a 18x7.5 5x114.3 offset 45 wheel
sounds ok???
wana make sure be4 i go...
Old 09-26-2003, 12:56 PM   #8 (permalink)
SCORPION6's Avatar
I think that with both will be ok 215/35 and 225/40 with 18x7.5 5x114.3 offset 45 wheel. I little out but ok. Maybe the problem with the 225 will be if you carry weigh on the back seat/trunk
Only an oppinion
