Old 09-22-2003, 02:06 PM   #1 (permalink)
Default Stock Tires on Sport Pkg
Does anyone else out there have a rough ride with the sport package? I think it's mainly due to the stock Michelin tires. They seem to literally leave the road for a split second whenever I hit any size crack or hole in the pavement, and it's even worse when i hit one on a turn. They just don't stick to the road at all.
Any suggestions on an upgrade? Perhaps Pirelli or Falken's. I did the RevItUp and the Falken's seem to stick like glue. And since I live in Minnesota, I also want a tire that's going to perform well in the snow and rain.
Any help would be greatly appreciated.
langsta6 is offline   Reply With Quote
Old 09-22-2003, 02:41 PM   #2 (permalink)
Default Reading Topic: Stock Tires on Sport Pkg
If you think the OEM tires are stiff you definitely don't want Falken Azenis. Plus they are not a tire you can run in snow, no how, no way.
LBJay is offline   Reply With Quote
Old 09-22-2003, 02:55 PM   #3 (permalink)
so then what tires would you recommend?
Old 09-22-2003, 08:13 PM   #4 (permalink)
mitchfried's Avatar
I had the Michelin Pilot Sport A/S (all season) on my Maxima. A huge improvement over the Bridgestone RE92. I recently replaced the stock 215/50/17 Michelins on my Mazda6 with 225/45/17 Bridgestone RE750's. Stickier, better ride, a little more road noise, but NOT all season. A non-issue here in Florida, but not where you live in the winter. Maybe the RE750's in the nice weather, then a switch to snow specific tires in the winter for you? There aren't a lot of choices in the stock size of 215/50/17.
Check out tirerack.com for the survey results for our stock Michelins. They are the LOWEST rated in their class.
mitchfried is offline   Reply With Quote
Old 09-23-2003, 09:51 AM   #5 (permalink)
Default Replying to Topic 'Stock Tires on Sport Pkg'
QUOTE
Originally posted by langsta6
* * * * * * so then what tires would you recommend?[/b]
I've heard good things about the the Sumitomo HTR+ as an all season performance tire. But if I lived where you do (MN) I would probably invest in a set a dedicated winter tires and rims.
Any tire that would be a great summer tire (sticky) will probably end up being terrible, if not dangerous, in the extreme cold of winter.
Old 09-23-2003, 10:19 AM   #6 (permalink)
I would suggest having a second set of wheels/winter tires, then put performance tires on the other set...
If you stick w/ one set of wheels, you are going to have a serious compromise in performance, noise, etc.
Eric Wong
tireswap is offline   Reply With Quote
Old 09-23-2003, 12:35 PM   #7 (permalink)
Yah, the ride of the stock Michelins makes me not want to put anything on the car that is stiffer than a V rated sidewall. I would love something stickier that rides better and quieter than the stock tires because they are just mediocre. I used to run Firestone SZ 50's and SZ50 EPs on my Probes and I LOVED them, but they will be too hard for the 6. Too bad since Tirerack is selling them for under $100 in the stock size.
Old Cars:
06 Mazdaspeed 6 Grand Touring, Platnum
03 Mazda 6s MTX, Lapis Blue
New Car:
08 Acura RDX, Tech Package, Nighthawk Black
Wife's Car:
07 Mazda CX-7 Touring, Copper Red
Blue Mazda is offline   Reply With Quote
Old 09-23-2003, 12:45 PM   #8 (permalink)
Gruss's Avatar
Send a message via AIM to Gruss Send a message via Yahoo to Gruss
Find someone selling the 16" stockers, they ride better than the 17" and do ok in the snow
'03 Mazda6 S
'03 Explorer
'97 VFR
Gruss is offline   Reply With Quote
Old 09-23-2003, 04:59 PM   #9 (permalink)
QUOTE
Check out tirerack.com for the survey results for our stock Michelins. *They are the LOWEST rated in their class.[/b]
That doesn't surprise me at all. I might just leave the stock set on for the winter then upgrade in the spring. I don't know too much about tires, so I might swing by the local tire dealer and see what they recommend.
Thanks for all the advice!
