Old 07-10-2003, 11:03 PM   #1 (permalink)
Default Front wheels spotting...
I know that the front two wheels are subjected to more brake dust than the other two. Mine are starting to spot...like water spotting, but I can't seem to get rid of it. I am using Armor All Wheel Cleaner...is this what's causing it? Is anyone else having this problem? I have only had the car a week and a half and it bothers me. The back two wheels look like they did off the lot.
2005 Black Cadillac CTS 3.6L
tucker is offline   Reply With Quote
Old 07-10-2003, 11:28 PM   #2 (permalink)
84FordMan's Avatar
Default Reading Topic: Front wheels spotting...
Like on nearly every car out there, the front brakes do the majority of the stopping, this is why you would replace the front pads more often than the rear shoes (On drum applications) or rear pads. This is why most front rotors start out life around 1.5mm at least and the rear usually start life at 1mm or less, less wear on the rear.
So more work to stop the vehicle, more brake dust.
1994 Mazda B3000 SE
Daily driver
84FordMan is offline   Reply With Quote
Old 07-10-2003, 11:54 PM   #3 (permalink)
That doesn't answer my question though...my question is: no matter how hard I scrub, the front wheels look water spotted...not sure if it's the armor all or what?
Old 07-11-2003, 12:36 AM   #4 (permalink)
rob
rob's Avatar
Send a message via AIM to rob
mothers makes a mag and aluminum wheel polish...its a cream that you massage into the surface...it might take the spots off...its worth a shot...
if it does work..give your wheels a coat of wax after they are cleaned...it will help keep the break dust from sticking...
hope this helps..
my6
rob is offline   Reply With Quote
Old 07-11-2003, 01:39 AM   #5 (permalink)
SC3
SC3's Avatar
Send a message via AIM to SC3
I'm assuming you have the Mazda 6 stock rims.
I'm pretty sure that the rims are painted, so you have to treat it like any other painted surface. There are wheel cleaners available; just make sure it is designed for either painted wheels or for all wheel surfaces. If you don't have wheel cleaner try Mequiar's Clear Coat Body Scrub Paint Cleaner.
I wouldn't recommend using aluminum wheel polish since it was designed to polish bare metal surface wheels and may likely strip the paint.
-SC3
SC3 is offline   Reply With Quote
Old 07-12-2003, 01:52 PM   #6 (permalink)
Thanks for the replies guys...will try. SC3, yes, I have the stock s trim whells (alloy).
Old 07-12-2003, 04:59 PM   #7 (permalink)
Default Replying to Topic 'Front wheels spotting...'
Yeppers.....Mothers Mag & Aluminum polish......awesome stuff for this kind of crap! :D
Robareski is offline   Reply With Quote
Old 07-12-2003, 05:37 PM   #8 (permalink)
rob
rob's Avatar
is that true though about the painted finish...i didn't mean to steer anyone in the wrong direction, i have a can and was about to polish the rims...but i will wait for a definate answer...
my6
Old 07-15-2003, 10:45 PM   #9 (permalink)
rob...that was the answer to my problems...did take a little bit of work though...:D
