Old 06-27-2003, 08:12 PM   #1 (permalink)
mitchfried's Avatar
Default Oversize width tires on stock wheel
Asked a local tire dealer about the wisdom of putting wider than recommended tire (235/45/17) on 7 inch width wheel. He thought it wouldn't wear properly, but otherwise wasn't dangerous. I may just stick with same size 215/50/17 Yokahama.
mitchfried is offline   Reply With Quote
Old 06-28-2003, 03:51 AM   #2 (permalink)
White 6s's Avatar
Send a message via AIM to White 6s Send a message via Yahoo to White 6s
Default Reading Topic: Oversize width tires on stock wheel
correct sizing would be 225-45-17 for a wider section tire
--ed
07 mazdaspeed3 GT black mica
06 yamaha r1 raven
93 honda civic hatch --project--
03 Mazda 6s May u Rust in peace
White 6s is offline   Reply With Quote
Old 06-28-2003, 05:21 AM   #3 (permalink)
I had 235/45/17 on my other car which has 7 inch rim width.It looks ok and actually look better than expected.No problem with tyre performance though.
M6Gr8 is offline   Reply With Quote
Old 06-28-2003, 07:05 AM   #4 (permalink)
mitchfried's Avatar
Default Replying to Topic 'Oversize width tires on stock wheel'
235/45/17 would be closest in overall diameter to the stock tire, giving the most accurate speedometer rating. Tire Rack publishes the factory specs for each tire, giving the diameter and revolutions per mile. It's interesting to note that the width and diameter of a tire in the same "size" can vary from manufacturer to manufacturer, as much as a half inch in width or diameter.
