K&N 69 Series Typhoon Air Intake System p/n 69-60 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 1 (permalink) Old 08-19-2009, 12:04 AM Thread Starter
tunertools's Avatar
Send a message via AIM to tunertools
Product ID: KN-69-6026TS
Manufacturer: K&N Engineering
K&N 69 Series Typhoon Air Intake System p/n 69-6026TS for the 2003-2007 Mazda 6 w/ 3.0L V
<div align='center'>
K&N 69 Series Typhoon Air Intake System p/n 69-6026TSThis filter fits: 2003-2007 Mazda 6 w/ 3.0L V6
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon&#39;s have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle&#39;s restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine&#39;s RPM range.
•Designed for increased performance for your sport compacts, utilizing the finest quality components
•Available in high-quality finishes
•Guaranteed to Provide more HP and Increased Acceleration
•Engineered to Specific Vehicle Design
•Easy to Install, Usually in 90 minutes or less!
•Lasts up to 100,000 Miles Before Service is Required (depending on driving conditions)
•Million Mile Limited Warranty
•Replaces OEM Filter and Air Box
•Air Filter is Washable and Reusable
•Works with Original Equipment Manufacturer Computer Systems
•Designed to use Factory Holes & Mounting Points Whenever Possible
This K&N performance replacement filter fits the following vehicles;
2007 MAZDA 6 3.0L V6 F/I - All CARB Exempt: No
2006 MAZDA 6 3.0L V6 F/I - All CARB Exempt: No
2005 MAZDA 6 3.0L V6 F/I - All CARB Exempt: No
2004 MAZDA 6 3.0L V6 F/I - All CARB Exempt: Yes
2003 MAZDA 6 3.0L V6 F/I - All CARB Exempt: Yes
<blockquote><blockquote>Thanks,
Lloyd</blockquote>
</blockquote>
tunertools is offline
